Author Topic: cherry,alps only "true" mechanical switches?  (Read 3066 times)
Offline typo
« on: Sun, 06 February 2011, 23:37:57 »
i am sure this has been discussed ten milion times. just for the record.
yes, topre and model m have mechanical means of actuation, but:
i mean a switch that has a mechanical electrical contact in the true sense of the term. ie, it does not press a plunger, spring or other device against a menbrane on a pcb or film. nor capacitive afaik.
are there currently any in production besides cherry and alps?
hint: fukka is alps but you know that already.
discuss.
Offline jaynoon
« Reply #1 on: Sun, 06 February 2011, 23:49:24 »
Check the key switch wiki. Pretty sure my Futabas would qualify, but honestly, who cares what the details are, as long as it feels good & lasts long I'm happy.
Home: Filco Tenkeyless Brown | Work: KBC Poker w/ Reds | Laptop: MacBook Air Keyboard
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #2 on: Mon, 07 February 2011, 00:04:06 »
NMB Hi-Tek switches also probably qualify.
NEC Blue Sliders could probably be categorized under ALPS as well, though it activates quite a bit differently.
Along with SMK Monterey switches.
« Last Edit: Mon, 07 February 2011, 00:08:49 by HaaTa »
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #3 on: Mon, 07 February 2011, 00:13:04 »
I suppose one could claim that even though a Model M isn't "mechanical" in the sense of having a membrane component just like many rubber domes... a Model F is not disqualified in that fashion.
Offline msiegel
« Reply #4 on: Mon, 07 February 2011, 00:19:35 »
so this definition of "mechanical" requires... a conductive metal switch?
there was an earlier definition that required a lever, instead.
it's weird what falls into and outside of each different definition :)
Offline typo
« Reply #5 on: Mon, 07 February 2011, 02:48:21 »
correct me if i am wrong, ripster. it seems like you are not a topre fan?
Offline manfaux
« Reply #6 on: Mon, 07 February 2011, 02:55:24 »
I hate Torpes, they are so overpriced!
Offline ch_123
« Reply #7 on: Mon, 07 February 2011, 03:22:16 »
Offline quadibloc
  • Layout Fanatic
« Reply #8 on: Mon, 07 February 2011, 10:32:16 »
Quote from: ripster;291238
I just like picking on the most expensive keyboard (next to the ergos and real exotics) because Topre is just resting on their laurels and never doing anything new.
Although the Customizer is a very competitively priced keyboard, it seems that Unicomp should be quaking in its boots about now.
Offline quadibloc
  • Layout Fanatic
« Reply #9 on: Mon, 07 February 2011, 17:11:59 »
Quote from: ripster;291068
But that would be like me mentioning scissor switches are pretty mechanical.
Hey, I have two macally keyboards that use scissor switches to provide a mechanical keyboard quality tactile feel at a reasonable cost.
