Author Topic: Key Source International Wombat POS Keyboards (KSI-1293)  (Read 4322 times)
Offline REVENGE
« on: Tue, 08 February 2011, 15:11:04 »
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160470251302
These are compact POS keyboards with a somewhat strange layout, full hardware programmability through a Windows XP utility, card readers, and a trackpoint mechanism.
I've contacted the seller and he has posted pics of the switches, they are black. In addition, I called KSI this morning and they told me that their 12XX series used mostly blacks, but some clear switches as well (don't expect any in this auction to be clear though).
These boards were used by the likes of RadioShack. The 12XX series was discontinued in favor of the mostly membrane based 13XX series, but some of the early 1392s used Cherry blacks as well.
Datasheet with detailed specs and layout here: http://www.ksikeyboards.com/drivers/KSI-129X%20User%20Manual.pdf
Offline keyboardlover
« Reply #1 on: Tue, 08 February 2011, 15:15:28 »
Just curious, does the Windows XP utility work in Windows 7?
Offline REVENGE
« Reply #2 on: Tue, 08 February 2011, 15:20:36 »
Quote from: keyboardlover;291921
Not sure, I imagine it might work on 32bit systems, probably not on 64 bit though.
http://www.ksikeyboards.com/support.php
It's possible that the actual keymap generating utility is DOS only, so I imagine you need access to an XP (or 32bit Windows) installation to get everything to work.
Offline elbowglue
« Reply #3 on: Wed, 09 February 2011, 11:33:09 »
Damn this is a cool keyboard!!
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
