Author Topic: Whats compatible with noppoo bottom rows?  (Read 2028 times)
Offline calavera
« on: Thu, 10 February 2011, 02:29:19 »
What keyboard with double shot keycaps out there are compatible with the bottom row (ctrl, alt, win, spacebar, menu) and right shift from a nopoo choco mini?
It looks like you'd need several donors to replace them all. :(
Also, the noppoo keycaps seem to be narrower than cherry corps keycaps so will they even be compatible with any keycaps?
Offline sixty
    • http://deskthority.net
« Reply #1 on: Thu, 10 February 2011, 02:33:32 »
Left CTRL, Left ALT, Right CTRL = Any vintage 101 key Cherry set
Right ALT, WIN, R_SHIFT = Vintage g80-1800 with windows keys, very rare in double shot form.
Offline calavera
« Reply #2 on: Thu, 10 February 2011, 02:40:44 »
thanks sixty! So I can assume other keycaps will fit fine in the noppoo keyboard? It might be the pics but the keycaps seem narrower vs. fairly squared shapes of cherry corps keycaps.
Looks like right ALT would be impossible to find.
Offline sixty
« Reply #3 on: Thu, 10 February 2011, 05:39:49 »
Forgot about caps lock. That will need modification, or a very very rare donor board from the 8000 series.
