Author Topic: I am torn!  (Read 4345 times)
Offline hfcobra
I am torn!
« on: Thu, 10 February 2011, 02:43:17 »
I just cant seem to decide what to use which keyboard for!  If anyone has a realforce with variable weights or a cherry mx brown board how do you like to use it?  I find they are both just awesome at everything and i dont like going through the hassle of changing keyboards all the time, but then again i want to use both of them since they are both great!   :P
Own/Love: REɅLFORCE 87UB EK Edition 45g
Have owned/used: Realforce 103-UB, XArmor U9BL, Filco Majestouch 104-key with Cherry MX Blues, Browns, and Reds, Steelseries 6gv2, Leopold with Browns
Offline spearson
I am torn!
« Reply #1 on: Thu, 10 February 2011, 03:05:31 »
I am in the exact same boat as you, lol.  Currently using the MX Browns since last week.
Offline hfcobra
I am torn!
« Reply #2 on: Thu, 10 February 2011, 03:25:31 »
its a good problem to have and one that many geekhackers would not mind having i am sure.   :P    I still wish i could at least find a good place to set one of the boards so that i could switch them out without unplugging either one ever.
Offline Tony
I am torn!
« Reply #3 on: Thu, 10 February 2011, 03:38:51 »
I want to be an octopus so that I can use a lot of keyboards at the same time.
You can toss a coin and let it decide for you...
Offline hfcobra
I am torn!
« Reply #4 on: Thu, 10 February 2011, 03:40:47 »
the problem is that i have both and i dont know which to use since they both do everything well for me.   :P
I am not deciding on which to buy lol
Offline calavera
I am torn!
« Reply #5 on: Thu, 10 February 2011, 03:55:23 »
Well, at one point I had three keyboards connected so I can switch whenever I like. Now I have two connected and I go back and forth. Unless you have a very small desk, why not just leave them both connected? :)
Offline hfcobra
I am torn!
« Reply #6 on: Thu, 10 February 2011, 04:10:53 »
i have nowhere to put the other one while they are both connected lol   :P   maybe i can clear up some space or put one on the tower....  hmmmm
Offline Tony
I am torn!
« Reply #7 on: Thu, 10 February 2011, 04:54:45 »
Your left hand can be on one keyboard while your right hand can be on the other.
Trouble will happen when you want to press shift lol
Offline iMav
  • geekhack creator/founder
I am torn!
« Reply #8 on: Thu, 10 February 2011, 06:33:47 »
Rotate monthly.  Gives you something to look forward to month to month.
Do you work from home, or is having one at work and one at home an option?
Offline itlnstln
I am torn!
« Reply #9 on: Thu, 10 February 2011, 06:49:33 »
I have both Cherry browns and a variable-weight Realforce.  I just swap out when I get all nostalgic for the other 'board.  Now with the Noppoo, I'll type on the RF for about 5 minutes, and switch back to the Noppoo.  The Cherry browns always reel me back in.
Offline theferenc
I am torn!
« Reply #10 on: Thu, 10 February 2011, 08:56:24 »
I have space under my monitor to hold either my customizer or my hhkb, whichever I'm not using. I do tend to leave both plugged in when I'm home, though the hhkb does travel with me.
They sit on the stand of the monitor, and on the Customizer, the monitor bezel sits over the number row, if that tells you how far it sticks out onto my desk. My desk isn't particularly deep, but it still feels like enough room to me.
Offline stuiees
I am torn!
« Reply #11 on: Thu, 10 February 2011, 10:44:19 »
I used to switch between keyboards depending on what I was doing.  It became a hassle, and when I would change out boards for gaming it always seemed to take longer to warm up.  Since, I have decided to stick with my RF for everything.
I like Topre!
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
I am torn!
« Reply #12 on: Thu, 10 February 2011, 11:21:32 »
Currently own a Noppoo Choc with Browns and Realforce variable weight 103UB.  I'd say that I much more enjoy gaming with the Noppoo Browns over the realforce, however, I love typing on the realforce.  So, if I had to categorize them:  Noppoo Browns for gaming, Topre/Realforce for typing.  I also love blues for gaming...
Offline bugfix
I am torn!
« Reply #13 on: Thu, 10 February 2011, 11:32:09 »
Why would one drink vodka? It doesn't even taste good.
*~Unicomp and Topre fan~*
I have:
Unicomp Customizer 105 German
Realforce 105GR
Unicomp Spacesaver German/Ansi hybrid(Current favorite)
I want:
Realforce 88GER
I used to have:
DAS Model S Ultimate EU (Sold)
Offline Reaif
I am torn!
« Reply #14 on: Thu, 10 February 2011, 12:06:28 »
Quote from: bugfix;292874
You don't drink vodka for the flavor... or lack thereof.
That being said, I would recommend bringing one to work, assuming you have a desk that someone else isn't likely to use. If that isn't the case, I would recommend setting up some usb extensions that end up right underneath your monitor, so that switching keyboards is quick and painless. I just started doing that because I have the same problem, but on the other end of the spectrum. I have two places to use a good keyboard, but only one keyboard to use, so I have been bringing it to and from work.
« Last Edit: Thu, 10 February 2011, 12:08:47 by Reaif »
Currently own:
Das S Ultimate with Browns
Cherry G84-4100 with ML Linear switches
Memorex Telex with NMB Space Invaders
Leopold with Blues
Offline pitashen
I am torn!
« Reply #15 on: Thu, 10 February 2011, 12:48:48 »
You want to sell one once you decide which one to stick with?
if not just keep them and switch from time to time. Thats what getting mech kb is about :P
Offline hfcobra
I am torn!
« Reply #16 on: Thu, 10 February 2011, 13:36:16 »
alright, i think ill go with iMav's idea of switching every month or so.   That way i am not switching the boards too often and i still get to enjoy both of them equally   :)
woody
  •  Guest
I am torn!
« Reply #17 on: Thu, 10 February 2011, 16:55:39 »
Quote from: ripster;292872
Put a bottle of Vodka on your table.  Drink liberally and frequently.
The first keyboard you spill on will get fried and the problem is solved.
This is called "Russian Keyboard Roulette".
Harharhar. About to go to bed, and this guy cracks me up.
Offline hfcobra
I am torn!
« Reply #18 on: Thu, 10 February 2011, 17:20:35 »
Quote from: woody;293061
lol, you know that 2 kids had to go to the hospital because they were playing Russian roulette with a semi-automatic pistol?  Too bad neither of them died, would have rid the world of some stupid for a change.   :madgrin:
Offline stuiees
I am torn!
« Reply #19 on: Thu, 10 February 2011, 17:29:55 »
Quote from: hfcobra;293074
lol wtf?  2 kids?  after the first one shot himself, the second was like "what are the odds of another round being chambered?" duhh its a semi auto...?  that is natural selection at its finest.  too bad it failed to complete the job.
I like Topre!
Offline hfcobra
I am torn!
« Reply #20 on: Thu, 10 February 2011, 19:10:23 »
that is exactly what i said, almost verbatim    XD
