Author Topic: Key "Enter" on Cherry G80-3000  (Read 6542 times)
Offline vodoleyy
« on: Thu, 10 February 2011, 05:02:11 »
I've visited many shops and salers online and noticed that some of these keyboards (on photos) had "enter" either in one row or in two rows. Does the Cherry company really produce 2 types of layout? Does anybody know?
« Last Edit: Thu, 10 February 2011, 05:25:18 by vodoleyy »
Offline Minskleip
« Reply #1 on: Thu, 10 February 2011, 05:28:10 »
At least they do ANSI and ISO, if that's what you mean.
What\'s in the back of my car? A cdr lol
Split Tipro keyboard with R3 keycaps
Offline vodoleyy
« Reply #2 on: Thu, 10 February 2011, 08:26:21 »
Quote from: Minskleip;292767
 Thx;) This is what i need!
Offline vodoleyy
« Reply #3 on: Sun, 13 February 2011, 07:57:02 »
Thank you very much! I'm novice on Geekhack, as you see.
Offline Ekaros
« Reply #4 on: Sun, 13 February 2011, 08:08:56 »
Quote from: vodoleyy;292763
All major keyboard makers produce atleast these two layouts and then the different text for them.
Smaller makers might do only Ansi though... ISO is old layout and used in Europe.
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline bugfix
« Reply #5 on: Sun, 13 February 2011, 08:59:32 »
Quote from: Ekaros;294363
And hated everywhere for some reason.
*~Unicomp and Topre fan~*
I have:
Unicomp Customizer 105 German
Realforce 105GR
Unicomp Spacesaver German/Ansi hybrid(Current favorite)
I want:
Realforce 88GER
I used to have:
DAS Model S Ultimate EU (Sold)
Offline mSSM
« Reply #6 on: Sun, 13 February 2011, 09:02:57 »
No need for the ISO layout, IMO. At least my fine motor skills are good enough to hit that (still pretty big) enter key in the ANSI layout - and also you have the bracket and backslash keys in great positions!
Offline Ekaros
« Reply #7 on: Sun, 13 February 2011, 09:05:59 »
Quote from: mSSM;294380
On other hands US only know one language and don't care if some of us happen to need more keys. Non universal desing is bad design anyway... Not that ISO is a lot better, but more is more... ;D
Also, that one key is ugly...
[SIGPIC][/SIGPIC]
Offline bugfix
« Reply #8 on: Sun, 13 February 2011, 09:11:54 »
Quote from: Ekaros;294381
Arrogant Americans ignoring my special characters....:yell:
äöüÄÖÜß
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline mSSM
« Reply #9 on: Sun, 13 February 2011, 09:18:05 »
Use LaTeX:
\"{a}
\"{o}
\"{u}
\"{A}
\"{O}
\"{U}
\ss
All you need! :-D
Offline Ekaros
« Reply #10 on: Sun, 13 February 2011, 09:19:33 »
Quote from: mSSM;294387
Use LaTeX:
\"{a}
\"{o}
\"{u}
\"{A}
\"{O}
\"{U}
\ss
All you need! :-D
I suggest we should remove ability to directly type any letter ;D
[SIGPIC][/SIGPIC]
Offline bugfix
« Reply #11 on: Sun, 13 February 2011, 09:48:33 »
Use LaTeX:
And how does one use that on a an Internet forum? Or in an email? Or in a IM program?
Also how the f does Latex even work?
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline theferenc
« Reply #12 on: Sun, 13 February 2011, 09:53:22 »
Actually, it does work in several IM clients.
LaTeX is like HTML. It's a markup type language, that has to be run through an interpreter. It's very easy to use, once you get the hang of it, but it does have a bit of a learning curve.
Offline bugfix
« Reply #13 on: Sun, 13 February 2011, 09:54:22 »
Can't you just use Word :P
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline theferenc
« Reply #14 on: Sun, 13 February 2011, 09:54:58 »
Actually, no, it doesn't work for what I need to do.
Just to clarify:
Word is a poor choice for a technical document for many different reasons. The need to include (one or more of) mathematics, figures, code, greek letters, embedded post script, footnotes, end notes, any number of other things I'm probably forgetting, and have a uniform, consistent look through the paper sort of invalidates word as an option. Word has trouble with long documents (100 pages causes it to seriously choke), which is not uncommon in academia.
Basically, it comes down to proper tool for the job. TeX and it's variants are the proper tool for math, science, and technical writing. Word is the proper tool for something, even if I haven't found it. Undergrads typing papers, secretaries sending out memos, maybe other cases I have no use for?
« Last Edit: Sun, 13 February 2011, 09:59:48 by theferenc »
Offline bugfix
« Reply #15 on: Sun, 13 February 2011, 09:56:44 »
So when I write a text, I would have to type things like all the time?
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline Ekaros
« Reply #16 on: Sun, 13 February 2011, 09:58:25 »
So umm if I want to write text document in pure UNICODE without any formating and stuff latex is great for it? ;D
[SIGPIC][/SIGPIC]
Offline theferenc
« Reply #17 on: Sun, 13 February 2011, 10:04:36 »
No no no.
Most latex interpreters handle unicode just fine. And it's much more usable than HTML, in my opinion.
bugfix, your example would be
Code: [Select]
\bf{stuff in bold}
Ekaros, you're right, for most frequent users of non-ASCII characters, that would be absurd. If it's all non-ASCII, you end up with something like the pinyin system, or whatever is used in Japan.
If it's partially non-ASCII, the only logical approach is a different layout on the keyboard, which is unfortunate from a certain perspective, as it makes this frustrating for multi-lingual people (assuming multiple non-english languages).
Offline bpiphany
« Reply #18 on: Sun, 13 February 2011, 10:25:33 »
Use LaTeX:
\"{a}
\"{o}
\"{u}
\"{A}
\"{O}
\"{U}
\ss
All you need! :-D
Actually it doesn't need to be that intricate
\"a = ä
\"o = ö
\aa = å
and so on does it too. It is still not feasible though =P
\documentclass{paper}
\begin{document}
Alla m\"anniskor \"ar f\"odda fria och lika i v\"arde och
r\"attigheter. De har utrustats med f\"ornuft och samvete och b\"or
handla gentemot varandra i en anda av gemenskap.
Var och en \"ar ber\"attigad till alla de r\"attigheter och friheter
som uttalas i denna f\"orklaring utan \aa tskillnad av n\aa got slag,
s\aa som p\aa grund av ras, hudf\"arg, k\"on, spr\aa k, religion,
politisk eller annan uppfattning, nationellt eller socialt ursprung,
egendom, b\"ord eller st\"allning i \"ovrigt. Ingen \aa tskillnad f\aa
r heller g\"oras p\aa grund av den politiska, r\"attsliga eller
internationella status som r\aa der i det land eller det omr\aa de som
en person tillh\"or, vare sig detta land eller omr\aa de \"ar
oberoende, st\aa r under f\"orvaltarskap, \"ar icke-sj\"alvstyrande
eller \"ar underkastat n\aa gon annan begr\"ansning av sin
suver\"anitet.
\end{document}
Offline mSSM
« Reply #19 on: Sun, 13 February 2011, 11:35:05 »
Well, the result counts! I agree, the plain text does not look too pretty, and it's not made to be read like that; but the result - awesome! :-D
Offline bugfix
« Reply #20 on: Sun, 13 February 2011, 11:52:11 »
OK guys you have convinced me, now you'll have the pleasure to explain how exactly the workflow is supposed to be (sorry for the hijacking).
I'll have to write a term paper in the coming weeks, how would I do that? Just type the text normally in a Editor and add things like bold or italics later?
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline Ekaros
« Reply #21 on: Sun, 13 February 2011, 11:54:46 »
Quote from: bugfix;294446
Try googling ;D
Still, LaTeX is for engineers who don't know anything about typesetting, you write the stuff and someone else who should know better makes out how it looks in the end.
[SIGPIC][/SIGPIC]
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #22 on: Sun, 13 February 2011, 13:16:51 »
Incidentally, UTF-8 has arrived in the TeX world, so no need to be afraid of exotic characters once stuff is set up properly.
(La)TeX has a good bit of a learning curve though. After all, the system has about 30 years of history. If you need decent results quickly, good templates are a must (I had some support from the department here when writing my diploma thesis). Even then, expect smoking head syndrome once in a while. Best grab a book and (as a Windows user) MiKTeX.
Offline theferenc
« Reply #23 on: Sun, 13 February 2011, 14:07:53 »
Best books out there are (in my opinion) the Mittelbach, Goossens, et al. LaTeX Companion (ISBN-10: 0201362996, ISBN-13: 978-0201362992).
If you need lots of graphics in your papers or the ability to generate a presentation using LaTeX, The LaTeX Graphics Companion (same authors) helps immensely (ISBN-10 0-321-50892-0, ISBN-13 978-0-321-50892-8).
Between them, these books cover nearly everything you would need for most editing needs.
Bugfix, in general, you don't add the formatting commands in afterwards, but rather as you go. Like I said, it shares a lot of similarities with HTML, but is actually more user friendly (I think). So most formatting commands are analogous, but there is no need to use commands for a new paragraph, just have a blank line to denote the end of the previous paragraph. See Prins Valium's example, and notice the empty line. That actually means something in TeX, which is quite helpful.
Feel free to shoot me a PM sometime if you need more help. I've taught more than my fair share of people how to use LaTeX, so I have a lot of resources ready to go. But I don't want to derail the thread any further.
And out of curiosity, what general area is the term paper in?
« Reply #24 on: Sun, 13 February 2011, 18:07:47 »
Quote from: theferenc;294483
Pretty good book, that, though I don't think it's the best introduction to the system.
It did make me laugh that I could declare a receipt for a "latex companion" on my taxes last year :)
Current collection: HHKB Pro 2 black on black, HHKB Pro 2 white/grey blank, [strike]Dell AT101W[/strike] (sold to SirClickAlot), 1992 Model M, Key Tronic Ergoforce KT 2001, BTC 5100 C. Dead boards: MS Natural Elite, MS Natural 4000.
Offline Minskleip
« Reply #25 on: Sun, 13 February 2011, 18:42:32 »
Read the Not so short guide to Latex (or something). Google lshort.pdf or lshort2.pdf. I don't remember what Latex's equivalent to CPAN is called at the moment.
I have the violet 'latex companion'. Good book too. It's not a reference like the latter.
Offline theferenc
« Reply #26 on: Sun, 13 February 2011, 18:50:42 »
Quote from: Minskleip;294556
CTAN, actually.
Quote from: Superfluous Parentheses;294544
Really? I actually find it quite approachable. But then, I think man pages are incredibly useful, as well. I guess I'm just a bit overtrained...
Offline Minskleip
« Reply #27 on: Sun, 13 February 2011, 18:52:36 »
Quote from: theferenc;294564
CTAN, actually.
Yes, thanks. These acronyms.. R has CRAN haha
