Author Topic: Possible Ricercar SPOS ends 5 hours  (Read 1417 times)
Offline elbowglue
« on: Sun, 13 February 2011, 06:01:23 »
Auction ends in 5 hours.
The picture is of a ricercar MX spos.  The auction is not clear if it is a ricercar SPOS or not.  I have asked the seller and he states the photo is of the actual keyboard (not a stock photo).  If he is correct about this then this is a ricercar spos.
Starting bid $20 + shipping, BIN for $60.
YMMV of course.
I don't trust this seller enough I think he may have used a stock photo.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250770621463&ssPageName=STRK:MEWAX:IT
Code: [Select]
 eBay sent this message to XXXX (elbowglue).
Your registered name is included to show this message originated from eBay. Learn more.
 Seller has responded to your question about this item
 Do not respond to the sender if this message requests that you complete the transaction outside of eBay. This type of offer is against eBay policy, may be fraudulent, and is not covered by buyer protection programs. Learn More.
Dear elbowglue,
Yes the picture is of the actual keyboard
- 1xmnemonicx Click "respond" to reply through Messages, or go to your email to reply
To: 1xmnemonicx
Subject: Details about item: elbowglue sent a message about CHERRY SPOS G86-62410 KEYBOARD #250770621463
Sent Date: Feb-08-11 09:40:02 PST
Dear 1xmnemonicx,
Is this picture an actual picture of the actual keyboard or is this a stock picture? I am looking for the G86 model which has "scooped" F and J keys (without nubs on them) is this the same kind? Thanks!
- elbowglue
Item Id: 250770621463
End time: Feb-13-11 09:07:48 PST
Seller:
 1xmnemonicx (72)
100.0% Positive Feedback
Member since Dec-08-08 in United States
Listing Status: This message was sent while the listing was active.
« Last Edit: Sun, 13 February 2011, 06:21:33 by elbowglue »
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline theferenc
« Reply #1 on: Sun, 13 February 2011, 08:01:32 »
If that is a ricercar SPOS, you can just get them straight from dell for $70. So why screw around with a potentially sketchy ebay seller?
Offline Soarer
« Reply #2 on: Sun, 13 February 2011, 08:23:15 »
Picture is clearly stolen from the Dell site!
IFF it says 'MX SPOS' on the label, it's a goodun.
Offline elbowglue
« Reply #3 on: Sun, 13 February 2011, 08:48:30 »
If I recall correctly Dell only sells the rubber dome version.  It's pretty much impossible to reliably find the MX ricercar version new from anywhere nowadays as it was a limited run to meet some purchaser's need for immediate keyboards (I think is what phaedrus said)
Yeah if this the pic is ripped off from the dell site this is most likely a rubber dome.
Offline theferenc
« Reply #4 on: Sun, 13 February 2011, 10:22:19 »
The model number stated has its first hit as the dell shopping site, so if they only sell the rubber dome, then either the seller can't read, or is mistaken about the cherry mx switches.
