Author Topic: any info on this NCR keyboard?  (Read 3404 times)
Offline calavera
Offline Moogle Stiltzkin
« Reply #1 on: Sun, 13 February 2011, 23:26:17 »
definitely double shot.
Switches ? donno :/
better ask the seller for pictures of back label, switch and underneath the keycap.
Royal Kludge discount code:
Lowyat15
15 USD discount.
Offline laden3
« Reply #2 on: Mon, 14 February 2011, 01:09:06 »
It is not very wise to use the word "definitely" here...
I rrrove brrracks.
« Reply #3 on: Mon, 14 February 2011, 01:27:21 »
Lowyat15
15 USD discount.
Offline laden3
« Reply #4 on: Mon, 14 February 2011, 02:55:07 »
I can't see any labels indicating that the keys are definitely double shots. I should take off my sunglasses :rolleyes: .
You know people don't like finding out that the double shots they are expecting are actually something else, right? It is like buying a G83 and found out that it is actually a rubber dome :clap2:.
I rrrove brrracks.
Offline sixty
    • http://deskthority.net
« Reply #5 on: Mon, 14 February 2011, 06:55:10 »
Going by the cable and the CTRL keys, I would suggest that its a rebranded/oemed WYSE Extended keyboard, most likely only compatible with terminals.
Offline calavera
« Reply #6 on: Mon, 14 February 2011, 07:08:46 »
if it's a rebranded WYSE keyboard, that would mean depending on the year there's a chance that this might be dye sub key caps?
Offline sixty
« Reply #7 on: Mon, 14 February 2011, 11:57:36 »
Quote from: calavera;294777
No. All WYSE are double shots made by SP.
Offline RiGS
« Reply #8 on: Mon, 14 February 2011, 13:27:08 »
You better off check this http://geekhack.org/showthread.php?t=15298 thread.
