Author Topic: Video Game Controllers + Mechanical Switches  (Read 10548 times)
Offline slueth
« on: Mon, 14 February 2011, 05:38:10 »
Do they make video game controllers with mechanical switches?  I only opened one controller in my life, it was a Sega Genesis. I had the controller way back; one of the buttons failed and I opened it up to fix.  It was a membrane button.  Imagine how great it would feel :X
Offline Maytan
« Reply #1 on: Mon, 14 February 2011, 10:03:40 »
There's the Razer Onza. (360 controller)
It doesn't use a Cherry switch or anything like that, but it uses microswitches like the ones you'd see in a mouse.
That's the closest thing I can think of. Though, I've heard of some people modding arcade sticks to use Cherry switches for the buttons.
« Last Edit: Mon, 14 February 2011, 10:09:35 by Maytan »
Offline itlnstln
« Reply #2 on: Mon, 14 February 2011, 10:11:10 »
Some arcade controllers are made with Sanwa switches.  If you were to make something custom, you might want to look into them.  The Mad Catz SFIV controllers had them if I'm not mistaken.
Offline Lethal Squirrel
  • I <3 60%
« Reply #3 on: Mon, 14 February 2011, 10:38:31 »
wow that bottom switch looks incredibly complicated.
I do know of one game controller that has mechanical switches. Guitar hero controllers. the strum bar uses alps. :)
or at least copies of alps
  • I <3 60%
« Reply #4 on: Mon, 14 February 2011, 11:42:55 »
oh so thats what is used in mice? It looks like there is a lot of stuff going on in that switch for how small they are
Offline fartbutt
« Reply #5 on: Mon, 14 February 2011, 21:40:06 »
If you mean just pads, the neo geo cd controller had microswitches in the dpad. The new marvel pad from PDP has microswitches in the dpad and the buttons as well.
http://www.pdp.com/p-984-versus-fighting-pad-marvel-edition.aspx
and of course all the arcade style controllers have mechanical switches.
Offline Arc'xer
« Reply #6 on: Mon, 14 February 2011, 23:55:26 »
Quote from: Lethal Squirrel;294867
Most of the mice on the market use 3-4 different switches depending on the position mostly from two companies. The most commonly used are from a company called Omron and the second most common are from a company called Zippy(mostly in sidebuttons).
As for the scroll wheel encoders I'm not really familiar which they use because there's a wide variety of choices. I guess you can say the same Omron and Zippy but I believe other manufacturers are used depending on the scroll wheel component needed.
The mice switches follow something similar to the cherry coloring system were different colors apply to different forces needed. They are quite small and come in different size offerings plus different operations like using a lever instead.
Mice microswitches aren't really followed much because well the construction of the mouse dictates more the feeling rather than the switch itself. A cheap mice with most common omron switch feels cheap as hell compared to a higher quality mouse body with most common omron switch.
I do know in some of the Asian countries in particular China(I think Thailand as well but I could be wrong), there's quite a following for replacing microswitches on mice(using more responsive and faster different feeling switches), Imnop even pointed this out a few months back(Going as far as to say some of the gamers over there break down their mice, clean them, and fix them and basically treat it like a weapon). Though most of the time they use the same companies Omron or Zippy; never heard of them using other companies like Saia-burgess and whatnot.
For example the deemed to be most popular of gaming mice the Intelli-family(IE 3.0, IO 1.1, WMO 1.1) are built out of extremely cheap material and many people have complained about it. And companies have even sold these mice at higher price points with a glossy paint-job(SS, Qpad, Zowie, Alienware, list goes on). But no company has literally reconstructed the mice out of high-quality plastics and components to eliminate the cheap feel. The microswitches on the IO 1.1/IE 3.0 may be the same(D2FC-F-7N) found on say the Razer or Logitech but because of the difference in material the Razer or Logitech feels a lot better despite using the same switches.
It's kinda hard for people to bother replacing them when usually the mouse itself is the issue at hand i.e. bodily feel not switch feel. Plus I think the amount of work in replacing the switches and soldering and making sure they work is a bigger hassle. Though it's a very interesting subject that isn't really discussed much.
Offline Mercen_505
« Reply #7 on: Wed, 16 February 2011, 15:48:14 »
They're around, here and there. I've got a bunch of arcade sticks and pads that have microswitches in them, but usually the buttons are still membrane based or similar. The DSi XL has microswitches in the dpad, which at first bothered me... but I grew to love over the course of a few short hours.
« Reply #8 on: Thu, 17 February 2011, 07:11:22 »
I'm guessing that some of these switches have an extra spring, so that the microswitch is pressed only at the bottom of the stroke.
Offline firestorm
« Reply #9 on: Thu, 17 February 2011, 07:56:01 »
The switches on the sides of my ColecoVision controllers are mechanical.  I'm not sure about the directional joystick... it's been a long time since I've dug into one of those.  I'm pretty sure the Quickshot flight stick I have for the NES has all micro switches, including the X/Y control.
