Author Topic: Modify a Rosewill RK-9000 LED?  (Read 1861 times)
Offline cgoldberg
    • http://goldb.org
« on: Mon, 14 February 2011, 16:37:26 »
I love my Rosewill RK-9000, but damn that blue LED is blindigly bright!
I have an almost identical Filco at work (under bright fluorescents) and never noticed this.  However, my Rosewill in my home lighting is like a laser staring me down.
Is it easy to replace with a dimmer LED?
any have info on changing a Filco/Rosewill LED to a lower power or diff color?
my temporary solution:
- Filco Majestouch 104 (Cherry brown) - metallic blue, usa
- Filco Majestouch Tenkeyless (Cherry blue) - black, usa
- PLU ML-87 (Cherry brown) - white, usa
- Rosewill RK-9000 (Cherry blue) - black, usa
- IBM Model M, 1989 (buckling spring) - beige, usa
- Unicomp SpaceSaver 104 (buckling spring) - black, usa
Offline DaemonRaccoon
« Reply #1 on: Mon, 14 February 2011, 17:27:35 »
I know what you mean, have you tried not staring into its welcoming blue glow?
I'd guinea pig this, but I don't have a soldiering iron or a multimeter right now. Also don't feel like voiding the warranty, yet. The dimmer LEDs will most likely require a resistor to account for the change in voltage. Then again I'm not an electrical engineer.
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline laden3
« Reply #2 on: Mon, 14 February 2011, 17:33:01 »
Make a LED condom... try some cellophane tapes
I rrrove brrracks.
Offline cgoldberg
    • http://goldb.org
« Reply #3 on: Mon, 14 February 2011, 17:37:13 »
@laden:
good idea
@ripster
thanks.. thats great
Offline RiGS
« Reply #4 on: Mon, 14 February 2011, 17:39:42 »
Quote from: ripster;295045
LED Mod instructions here.
Safe Electron Sex
Steelseries knows what they are doing. :)
Offline cgoldberg
    • http://goldb.org
« Reply #5 on: Mon, 14 February 2011, 17:40:13 »
ripster,
what color sharpie should I try on a blue LED to dim it.  just blue?
maybe I can use a fine point sharpie and not even have to open the case?
« Last Edit: Mon, 14 February 2011, 17:43:02 by cgoldberg »
