Author Topic: Idiot coworker: 1, Kinesis Frestyle: 0  (Read 5222 times)
Offline raeb
« on: Wed, 16 February 2011, 21:27:47 »
Damnit. He also tried to help by turning it upside down, while the keys were still on, to try and drain it.
GG Kinesis.  RIP
Offline DeltaGunner
« Reply #1 on: Thu, 17 February 2011, 03:00:16 »
Condoleances, cant you get the money from that guy that broke it?
[SIGPIC][/SIGPIC]
Keyboards:
Razer BlackWidow Ultimate
Wishlist:
DAS Ultimate Model S Ultimate Silent, or atleast some other Cherry Brown
Mice:
Logitech Trackball
Logitech Trackman Wheel
CM Storm Sentinel Advance 5.600 DPI
Switches:
Blue
Want to try:
Black, Brown, Red and BS
Offline bugfix
« Reply #2 on: Thu, 17 February 2011, 03:19:54 »
1. Let his insurance pay/Sue him
2. Buy a new one
*~Unicomp and Topre fan~*
I have:
Unicomp Customizer 105 German
Realforce 105GR
Unicomp Spacesaver German/Ansi hybrid(Current favorite)
I want:
Realforce 88GER
I used to have:
DAS Model S Ultimate EU (Sold)
Offline What is X?
« Reply #3 on: Thu, 17 February 2011, 03:44:29 »
Quote from: bugfix;296589
2. Buy a new one
3. ????
4. Break even
Offline kill will
    • http://www.jerseyshoredailies.com
« Reply #4 on: Thu, 17 February 2011, 04:33:30 »
u should get to do ANYTHING to his keyboard and he should buy u the same one no questions.
I <3 BS
Offline slueth
« Reply #5 on: Thu, 17 February 2011, 05:39:48 »
drop a duece in his muffler
Offline Surly73
« Reply #6 on: Thu, 17 February 2011, 07:15:31 »
Have you tried to save it?  There are lots of techniques to use, particularly if you have "nothing to lose".
Disassemble what's possible, immerse in distilled water, then 50:50 distilled water and alcohol, then warm air dry.
I know mechanical switches are involved, and any lubricants present could be washed out, but it's worth a try.  It might make you feel better than just pounding his face in...
Offline chimera15
« Reply #7 on: Thu, 17 February 2011, 08:13:00 »
It's not mechanical is it?  It'd be interesting to see if there are electronics in both sides of it, or if it's just in one side.  It may have 0 damage once it dries out if the chip is in the left hand, which is a good chance since that side has the numpad and such.  Although the right side does have the lights, so that might not be...
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline Surly73
« Reply #8 on: Thu, 17 February 2011, 09:07:55 »
Quote from: chimera15;296675
Lots of things can be saved, electronic or not.  The most critical thing is rapid response (especially if this is salt water, which I really doubt it is).  Things that are tough to save is sandwiched displays (liquid can get in but sometimes can't get out) and mechanical devices where grease can get washed out by further cleaning.
I would definitely disassemble and take whatever actions are necessary.  As I mentioned, with "nothing to lose" total immersion can save a lot of things.
Offline rantenki
    • http://armyofevilrobots.com/
quick solution to idiot co-workers...
« Reply #9 on: Thu, 17 February 2011, 10:49:31 »
Quote from: raeb;296488
GG Kinesis.  RIP
That's a stabbing:
And yes, I keed, I keed. If it had been an Advantage OTOH....
Offline raeb
« Reply #10 on: Thu, 17 February 2011, 23:26:06 »
Hah.  Awesome responses all. Turns out I'm saving it as we speak as the damage wasn't as bad as I initially thought. Some got between the plastic sheets of the grid though which is the most annoying part. Unfortunately it's not mechanical although the thought crossed my mind to attempt a transplant. Anyone got the body of a MX switch laying around?
« Reply #11 on: Fri, 18 February 2011, 07:47:00 »
How big are those square holes?
A Cherry MX switch fits in a square hole that is 14.0 mm wide, but the tolerances are small.
Offline theferenc
« Reply #12 on: Fri, 18 February 2011, 10:19:05 »
You would also need a custom PCB to do the transplant.
Offline chimera15
« Reply #13 on: Fri, 18 February 2011, 11:16:59 »
Quote from: theferenc;297241
You can figure out the matrix and use wires so you wouldn't necessarily need a pcb, as long as the switches are being held, but it's unlikely they will fit so well.
The toughest part if the switches actually did securely fit in those holes will be finding or making caps for a split board like that.
Alps boards:
Offline raeb
« Reply #14 on: Fri, 18 February 2011, 19:37:22 »
Quote from: chimera15;297257
Well, the base of the little towers might actually be just right on a rough measure. I'm not so sure the plastic would be strong enough without the metal plate supporting it.
I think we're SOL on the mechanical idea =\ Back to cleaning it. Anyone else have a similar thing happen to their KB?
Offline bpiphany
« Reply #15 on: Sat, 19 February 2011, 06:50:50 »
I spilled soup into a membrane keyboard once. No biggie, just took it apart and cleaned it up. Worked as good as ever afterwards.
Offline kill will
« Reply #16 on: Sat, 19 February 2011, 13:18:58 »
so did you shart on this guys keyboard or what ?
I <3 BS
Offline raeb
« Reply #17 on: Sat, 19 February 2011, 17:19:26 »
Quote from: ripster;297792
Odd looking sliders.  Unfortunately they seem to slide on standard grooves.
The Topre's are Mo Bettah!  I think this has a lot to do with the Topre key feel.
Not even grooves. Just a slight straight wall with 2 tabs to prevent the slider from going all the way in. If I had a decent camera I'd take better pics. Topre's lookin gooooood.
