Author Topic: What's the cheapest donor board I can buy for Cherry Keys, Black Color w/ White font?  (Read 2713 times)
Offline nocturn4l3030
^ what topic says.. did a google search and didn't find a particular thread on this
thx!
What happens when you discover GeekHack:
[strike]Black Ducky dk1087 Cherry (Brown)
Topre Realforce 103UB 55g
Cherry G80-8113HRBUS-2 (Clear)
White PLU ML-87 (Blue)
1990 IBM Model M 1391401
Cherry G80-3000LSCEU-0 (Blue)
[/strike]
Cherry G80-3600LYCEU-2 (Red)
Topre Realforce 86UB
Filco Tenkeyless (Brown)
[/SIZE]
Offline bugfix
Have you considered the group buy round three? I know it's not white on black, but those are some quality keys that would save you the hassle of harvesting them.
*~Unicomp and Topre fan~*
I have:
Unicomp Customizer 105 German
Realforce 105GR
Unicomp Spacesaver German/Ansi hybrid(Current favorite)
I want:
Realforce 88GER
I used to have:
DAS Model S Ultimate EU (Sold)
Offline manfaux
check out this thread!
http://geekhack.org/showthread.php?t=15107
and order a Moogle Black Patch kit, you are good to go
Offline cgoldberg
    • http://goldb.org
Quote from: nocturn4l3030;296676
thx!
I've had good luck with Cherry MY-7000 (various models of it).  They can usually be found on ebay for around $15 (shipped in USA) used, or $40 (shipped in USA) brand new in box.
But in general, Cherry "MY" boards are great for harvesting keys.  I don't like the MY switches, but nobody else does either... so the boards are dirt cheap and the keys are compatible with MX switches.
- Filco Majestouch 104 (Cherry brown) - metallic blue, usa
- Filco Majestouch Tenkeyless (Cherry blue) - black, usa
- PLU ML-87 (Cherry brown) - white, usa
- Rosewill RK-9000 (Cherry blue) - black, usa
- IBM Model M, 1989 (buckling spring) - beige, usa
- Unicomp SpaceSaver 104 (buckling spring) - black, usa
Offline Mr. Perfect
Is that your Filco in your avatar? That's a nice collection of caps you have there. There must be something to that MY board idea.
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline kidchunks
Only problem with harvesting keys from a MY 7000 is that the board comes with a small numpad 0 key and small + key. If you're doing this for a tenkeyless board then its perfect with a moogle black kit. If not, you may need to look at another board to harvest.
Topre || BS > *
my root : kidchunks[dot]com
Offline cgoldberg
    • http://goldb.org
Quote from: Mr. Perfect;296767
yup, thats my Filco!
