Author Topic: Find me this keyboard and be greatly compensated.  (Read 2854 times)
Offline kill will
    • http://www.jerseyshoredailies.com
« on: Thu, 17 February 2011, 16:22:20 »
DSI LARGE KEY KEYBOARD
http://www.ergocanada.com/products/keyboards/dsi_bigkey_keyboard.html
thats about the only info i can find on the keyboard.  supposedly it has mechanical switches.
I will pay a great deal for this keyboard.
I <3 BS
« Reply #1 on: Thu, 17 February 2011, 16:38:59 »
It seems like there are many of the type that you want on eBay.co.uk .Buy It Now at around £20.
Some sellers have specified that they ship to locations outside the UK.
Offline J888www
« Reply #2 on: Thu, 17 February 2011, 18:22:58 »
Here it is on eBay. If I purchased this product it will be probably lead to later regrets, I cannot say the same for you, but be warned though.
PS: No reward necessary.
« Last Edit: Thu, 17 February 2011, 18:25:28 by J888www »
Often outspoken, please forgive any cause for offense.
Thank you all in GH for reading.
Keyboards & Pointing Devices :-
[/FONT]One Too Many[/COLOR]
Offline kill will
« Reply #3 on: Thu, 17 February 2011, 18:32:05 »
can you find me the black edition.
as much as i love colored keycaps i dont wanna look like a pedo.
I <3 BS
Offline kill will
« Reply #4 on: Thu, 17 February 2011, 18:34:42 »
i think i found black options on that ebay, but are those the same dsi ones ?? i guess i have to contact the seller ... if they are mechanical switch it may be worth it to try.
I <3 BS
Offline kill will
« Reply #5 on: Thu, 17 February 2011, 18:35:19 »
and ripster i will most definitely not forget that item.  i just wish it had a big 0 instead of 00 set up.
I <3 BS
Offline kps
« Reply #6 on: Thu, 17 February 2011, 22:26:48 »
I've handled a Crayola-branded keyboard with this layout, and it was not mechanical.
Offline kill will
« Reply #7 on: Thu, 17 February 2011, 22:43:08 »
ya i dont think any of these are mechanical.  i read somewhere dsi makes one that looks exactly the same and its mechanical.  hmmmmmmmmmmmmmmmmmmmmm
I <3 BS
Offline Phaedrus2129
« Reply #8 on: Fri, 18 February 2011, 00:59:06 »
My uni has one in one of the labs, right next to the print station with the G80-8113. I never suspected it might be mechanical. I'll check it out Tuesday, that's the next time I have a class in that building.
I doubt they'd part with it though.
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline Oqsy
« Reply #9 on: Fri, 18 February 2011, 01:31:31 »
But do they make a version for the visually impaired?
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline Daniel Beaver
« Reply #10 on: Fri, 18 February 2011, 06:27:44 »
Steal it! To hell with the disabled!
Home: Topre Realforce 87W45  /  Mionix Naos 3200
Work: Topre Realforce 87B  /  Microsoft Intellimouse Explorer 3.0
Offline Pony
« Reply #11 on: Fri, 18 February 2011, 08:59:31 »
Quote from: kill will;296890
I was searching NewEgg the other day and came across this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16823658004
its only 69.99, so I don't think it will lead to much regret should the experience end as hideous as I believe it will. This version has function keys, is USB, and guessing isn't mechanical.
If I was going to consider one of these, I would go for yellow and try to convince anyone who saw it that I was going for a bumble bee theme.
« Last Edit: Fri, 18 February 2011, 09:06:34 by Pony »
Offline ch_123
« Reply #12 on: Fri, 18 February 2011, 12:05:55 »
Could well be ML switches.
Offline kill will
« Reply #13 on: Fri, 18 February 2011, 12:46:25 »
lol i didnt even know.  more rnd will be done on this board.
« Last Edit: Fri, 18 February 2011, 12:52:03 by kill will »
I <3 BS
Offline digitalleftovers
« Reply #14 on: Fri, 18 February 2011, 12:55:18 »
If you want large letters and mechanical switches (ALPS) then this may be your best bet:
http://dsi-keyboards.com/fullsizekeyboardwlargefontsivory.aspx
Same concept, except it does have mechanical switches.  I'm not a fan of this style, but I know it comes in black with white lettering.  I have seen it on amazon before for around $70 US, but I can't find it at the moment.
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
« Reply #15 on: Fri, 18 February 2011, 13:31:49 »
Quote from: Daniel Beaver;297146
That's your answer to everything, isn't it? :p
