Author Topic: Need a key cap source  (Read 2082 times)
Offline Felcom
« on: Fri, 18 February 2011, 08:12:03 »
Are there any online stores with a focus on selling high quality / novelty key caps? I searched the shopping wikis and it seems like most stores will have just replacement sets for the boards they offer (understandable). Where do you guys turn to get your high quality keycaps?
I have my first Filco Majestouch in the mail, but I think I'll eventually replace the key caps with some higher quality ones when they start to shine over. Are there complete sets (104 keys) of double-shot key caps that are compatible with Filco, or is that a pipedream?
 :roll:
Offline bugfix
« Reply #1 on: Fri, 18 February 2011, 08:33:31 »
Signature Plastics?
*~Unicomp and Topre fan~*
I have:
Unicomp Customizer 105 German
Realforce 105GR
Unicomp Spacesaver German/Ansi hybrid(Current favorite)
I want:
Realforce 88GER
I used to have:
DAS Model S Ultimate EU (Sold)
Offline Peter
« Reply #2 on: Fri, 18 February 2011, 08:42:06 »
No, Cherry never made a double-shot windoze-key or a 'Bill Gates' Documents' key .
The 'cheapest' way to get doubleshot keycaps is to buy a used Cherry-board from
eBay or some local auction-site .
And no, you won't win the auction if you only expect to spend 1 Credit .
Offline manfaux
« Reply #3 on: Fri, 18 February 2011, 08:47:10 »
Offline sixty
    • http://deskthority.net
« Reply #4 on: Fri, 18 February 2011, 10:52:56 »
Just for your info, Signature Plastic or even real Cherry Corp doubleshot keys will turn shiny all the same. That is just the way it is. ABS is not that forgiving to daily use.
Of course, while these keys do become shiny all the same, their legend stays in place, which is the main advantage of double shot keys.
Offline Felcom
« Reply #5 on: Fri, 18 February 2011, 17:23:59 »
You guys rock, thanks!
Offline .XL
    • http://www.paokfc.gr/
« Reply #6 on: Fri, 18 February 2011, 17:27:31 »
If you're looking for replacement keycaps I think you should check out PCHome for a set of ducky keycaps. They're pbt with a dark grayish lettering. Will fit on your filco and cost about $60 shipped to your door from Taiwan.
Keyboards: Filco Majestouch-2 87key Browns - Realforce 103UB 55g - Compaq MX11800 (ghetto clears + doubleshots)
Offline jdreamer
« Reply #7 on: Fri, 18 February 2011, 17:52:12 »
I have a Archiss/Lepold tenkeyless. Will Filco replacement fit mine? I know that spacebar doesn't fit but I'm looking for something like black on black or white engraved... Help? :D
My life for Aiur!
