Author Topic: Is there such a thing as PCB mount tenkeyless?  (Read 3377 times)
Offline Mr. Perfect
« on: Sun, 20 February 2011, 02:19:30 »
I'm interested in a tenkeyless with Cherry clears, but since no such thing exists and I don't know how to solder I'm wondering if there are any PCB mount boards that would be easy to do a switch mod on. I'm guessing not, but it's worth asking, right?:noidea:
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
« Reply #1 on: Sun, 20 February 2011, 03:48:02 »
I don't know of any, but you could mod a Cherry G80-1800, then remap the keys in either software or by routing wires on the PCB. But then, if you could reroute wires on the PCB, then you should also be capable of replacing the switches by soldering.
Offline keyboardlover
« Reply #2 on: Sun, 20 February 2011, 09:12:08 »
There are some Cherry boards in a space-saving layout, but not truly "tenkeyless". There's one on PCHome I believe with nkro and browns. Would you be interested in something like that?
Offline didjamatic
« Reply #3 on: Sun, 20 February 2011, 09:17:08 »
Only prototypes, but the G80-1800 and MX-11800 are compact, have a tenkey and are PCB mounted.
Offline Mr. Perfect
« Reply #4 on: Sun, 20 February 2011, 13:55:35 »
Quote from: keyboardlover;298222
Possibly. When searching for the Cherry G80-8113HRBUS-2 that you have in your signature, I did notice a few POS boards that look similar, but with the tenkeys cut off. Are those what you're talking about?
Quote from: didjamatic;298225
They're a little smaller then a fullsize, but was hoping to get closer to Filco tenkeyless size.
Might be time to learn how to solder, huh?
« Last Edit: Sun, 20 February 2011, 14:03:14 by Mr. Perfect »
Offline manfaux
« Reply #5 on: Sun, 20 February 2011, 14:00:34 »
Quote from: Mr. Perfect;298366
he's probably talking about something like this, it's got browns:
http://global.pchome.com.tw/?mod=item&func=exhibit&IT_NO=DCAH21-A53511797&c=A10&tm=u
compact but not a "tenkeyless", I've got one of these at home for my parents.
Offline Phaedrus2129
« Reply #6 on: Sun, 20 February 2011, 14:43:36 »
The Cherry SPOS MX is ultra compact, about the size of a typical tenkeyless board (maybe a little taller). PCB mount MX browns. Only problem is they're rare.
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
