Author Topic: Which doubleshot(group buy3) Ducky spacebar  (Read 2080 times)
Offline runeazn
« on: Sun, 20 February 2011, 06:04:50 »
Cherry/Filco/Ducky ................ (SPACEBLACK)
Cherry/Filco/Ducky ................ (SPACEGREY)
which for my ducky?
he says grey but is my ducky spacebar grey????
i think its black but???
« Last Edit: Sun, 20 February 2011, 06:08:23 by runeazn »
Kami Ducky 1087 of Heaven
Offline sixty
    • http://deskthority.net
« Reply #1 on: Sun, 20 February 2011, 06:13:17 »
I hope you realize that it will go shiny all the same.
Offline Culinia
« Reply #2 on: Sun, 20 February 2011, 06:17:58 »
If you are buying the main set i.e. STANDARD then the grey space bar will match the vintage keyboard theme. I personally am going to buy both black and grey to see how it will look like.
Unless you wanted to just replace space bar then ignore the above obviously.
Offline runeazn
« Reply #3 on: Sun, 20 February 2011, 06:33:02 »
only replacement :P
but heck if it is going to go shiny anyway i aint going to buy it.
i just wondered if it wouldn't go shiny fast..
g19 has good quality keycap >_> hasnt gone shiny after a year of use.
Offline Moogle Stiltzkin
« Reply #4 on: Sun, 20 February 2011, 08:05:38 »
spacebargrey i think means the same color as whiterice's double shot set. It was a dolche black color setting. The spacebar was a dark grey.
The filco/ducky bit just means it is compatible (the spacebar fits).
If you want a spacebar same like your Ducky get black color. If your getting 7bits entire kit then your gonna need the grey instead to match the color of his double shot set.
Ducky's pbt spacebar i found was pretty good.
Royal Kludge discount code:
Lowyat15
15 USD discount.
