Author Topic: cherry key caps, black, blank and flat window keys  (Read 3630 times)
Offline regicide
  • Software developer and Open source hacker
« on: Sun, 20 February 2011, 19:55:17 »
Hey all, looking for a set of key tops similar to http://www.armygroup.com.tw/shop/goods.php?id=5370
But without the bubbly windows keys.
Can be either tenkeyless or full, size of keys doesn't matter too much (as I make making my own board) however I do require 3 (or 2) keys left of the space bar and 4 right of it and the keycaps must fit onto a cherry stem.
Thanks all,
~Regi
2 Kinesis advantages (MX browns)
Offline mechkeyboards
« Reply #1 on: Sun, 20 February 2011, 20:26:09 »
Ducky blank PBT. ;)
Offline bakageta
« Reply #2 on: Sun, 20 February 2011, 20:54:36 »
Can those even be ordered anywhere? I've been the black on black on taobao, but haven't seen the blanks. Keep in mind they do have the LED windows on the various lock keys as well as three of the f-keys.
Offline regicide
« Reply #3 on: Sun, 20 February 2011, 21:28:22 »
Thanks for your replies.
Any links from where I can order them?
However if they have the LED windows it may be a deal breaker, guess I should update my requirements huh :p
« Reply #4 on: Sun, 20 February 2011, 22:11:41 »
The Ducky pbt blanks don't have led windows.
Offline bakageta
« Reply #5 on: Mon, 21 February 2011, 00:04:21 »
Quote from: mechkeyboards;298594
Oh? Link please, I so need to replace my Filco's keys, the coating makes them go shiny ridiculously fast.
Offline regicide
« Reply #6 on: Mon, 21 February 2011, 19:42:20 »
Sorry the site I am getting them from only ships to Aus/NZ.
I wish you the best of luck, they are really nice looking keys.
Thanks guys!
Offline sLeezy
« Reply #7 on: Mon, 21 February 2011, 21:29:16 »
Quote from: bakageta;298635
+1 on that. The only downside to the Filcos are the keycaps.
Input Devices
Keyboard - PFU HHKB Pro 2 Esc WASD | Filco Majestouch Tenkeyless Esc WASD
Pointing Device - Logitech Performance MX
Offline bakageta
« Reply #8 on: Tue, 22 February 2011, 00:03:23 »
Quote from: regicide;299073
Thanks guys!
That's fine, link anyway, I'll find a middleman... :P
Offline regicide
« Reply #9 on: Tue, 22 February 2011, 00:39:41 »
http://www.mechkeyboards.com/keycap.html
Goodluck :)
You could also try duckychannel http://duckychannel.com.tw
 or from another thread here
find a ducky distributer closer to you.
« Last Edit: Tue, 22 February 2011, 14:16:23 by regicide »
Offline regicide
« Reply #10 on: Sun, 06 March 2011, 22:26:57 »
Sorry for posting in an old thread...
Just got the keycaps today, they are superb!
Each key has a very slight protrustion on the 'top' facing edge of the key in the center so if you drop a key you can quickly find its orientation :)
Very nice quality (the keys feel more textured compared to my das', its a very nice texture though).
Thanks again!
