Author Topic: Ducky 1087 with a KVM  (Read 2572 times)
Offline digitalleftovers
« on: Mon, 21 February 2011, 15:11:20 »
I'm probably just missing something simple here, but I can't seem to get my Ducky 1087 to work with my KVM.  I know that right Alt + Num Lock turns on scroll lock, but for some reason, pressing num lock again does not have the same effect as just pressing a normal scroll lock key twice.
To clarify, I have a d-link 4 port ps/2 KVM here.  I have the ducky plugged in with an adapter.  This KVM uses "scrl lock + scrl lock + [Number]" to switch computers.
To make things more confusing, I believe that it can work because when mashing right alt and num lock I am able to get a beep out of my KVM, but I can't reproduce the key combination consistently.  I have made it beep by doing it a few times now.
If anyone reads chinese, this was the explanation given over on KBC:
"scrlk变成了numlk 如果要激活scrlk 同样需要alt+numlk 其实alt变成了一个fn"
Which google translates to:
" scrlk into numlk If you also need to activate scrlk alt alt + numlk in fact become a fn"
alt alt + numlk doesn't seem to do anything different from just alt + numlk.  Any ideas?
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
« Reply #1 on: Tue, 22 February 2011, 12:41:40 »
I thought if I phrased the question differently, it may elicit more interest.
I am wondering if there is a significant different between activating a key like ScrLk (for use with a kvm) with a dedicated function key (fn) or with a modifier key (like Alt).
My concern is that, while software doesn't care what is used as a modifer, hardware does.
If anyone has any insight on this, please post it here.
Keyboards:
« Reply #2 on: Mon, 18 July 2011, 02:45:21 »
In case anyone cares, I just hooked up my ducky 1087 and filco to play with aquakeytest.  The key codes for scroll lock between the two boards are identical, yet the filco works with a kvm and the ducky doesn't.  I figured that I would update this in case anyone else wondered.
Keyboards:
Offline pkeybank
« Reply #3 on: Tue, 19 July 2011, 20:16:56 »
well. i didn't read what you wrote. sorry tl;dr. however i saw soemthing chinese, and you asked please translate.
the above says, scroll lock turns into number lock, if you want to activate scroll lock, you also need alt + number lock. actually, alt turned into fn
SAY WHAT THE ****!?!!?
