Author Topic: Lego axles / Cherry stems?  (Read 6695 times)
Offline Izza
« on: Mon, 21 February 2011, 18:29:28 »
Just curious if anyone could do a comparison between Lego axles, and Cherry stems? I'm told there's a certain individual on the forums that eats/sleeps/breathes Lego, and might be able to help.
I'm also told to mention that no Legos will be harmed.
:smile:
[SIGPIC][/SIGPIC]
Offline keyboardlover
« Reply #1 on: Mon, 21 February 2011, 18:30:49 »
There is absolutely no one here like that. At all.
Offline Izza
« Reply #2 on: Mon, 21 February 2011, 19:01:07 »
Quote from: ripster;299043
Lego axles are longer.  I'm sure of it.
Yes, but will a Lego axle fit properly into a Cherry-compatible keycap?
Or rather, will a Cherry keystem fit into one of these axle bushings:
[SIGPIC][/SIGPIC]
Offline Arcanius
  • Buckling Spring Lover
« Reply #3 on: Mon, 21 February 2011, 19:13:19 »
I don't think so. If I remember correctly, the cherry stems are a bit... thinner in the plastic. Ie the bushing will go on, but not tightly enough to stay there.
But... I don't currently have a cherry board to try on, so this is really just speculation, I guess.
Offline nanu
    • http://T-T.be/portal
« Reply #4 on: Mon, 21 February 2011, 19:50:50 »
They don't fit. The lego axle plus shape is more stout and smaller in diameter. You would have to remove material to make it fit a keycap.
Offline Daniel Beaver
« Reply #5 on: Mon, 21 February 2011, 19:56:01 »
Cherry stems are somewhat thinner than the Lego axles.
Home: Topre Realforce 87W45  /  Mionix Naos 3200
Work: Topre Realforce 87B  /  Microsoft Intellimouse Explorer 3.0
Offline Izza
« Reply #6 on: Mon, 21 February 2011, 20:19:19 »
Quote from: ripster;299078
Why are you asking?
I had this crazy idea that I could use them as a "readymade" for custom keycaps.
Ah well... at least I know the answer now. Thank you, Daniel, for the image.
The search continues...
Edit: Mega Bloks... those had axle pieces as well, didn't they?
« Last Edit: Mon, 21 February 2011, 20:22:44 by Izza »
[SIGPIC][/SIGPIC]
« Reply #7 on: Mon, 21 February 2011, 20:22:47 »
ClickClack's gonna be jealous...
Offline bpiphany
« Reply #8 on: Tue, 22 February 2011, 00:04:38 »
The square 4 nub legos fit sort of snugly over a cherry stem, they dont quite fit into the switch though when pressed. I have an idea to do a ripster style transplant of cherry stems to some legos when I have the time. If noone else beats me to it *wink*
Offline Izza
« Reply #9 on: Tue, 22 February 2011, 08:50:11 »
Quote from: ripster;299206
Well,  the rubber dome version has already been done.  Doesn't look like much fun to type on.
Lego keyboard.
Now all you need are these:
[SIGPIC][/SIGPIC]
