Author Topic: how long are cherry mx blues activated for  (Read 2015 times)
Offline regicide
  • Software developer and Open source hacker
« on: Mon, 21 February 2011, 20:32:12 »
I was wondering given a light typist, how long would the cherry mx blue switches be 'closed' for?
As their activation and reset points are near the middle and very close, a typist who knew the switch well enough could have a very accurate press that activates the switch for a short period of time (at or just past the actuation point and then immediately release)
Is this kind of information available anywhere?
2 Kinesis advantages (MX browns)
Offline keyboardlover
« Reply #1 on: Mon, 21 February 2011, 20:37:14 »
I personally don't know, but I see you're from New Zealand. Sorry to hear about the earthquake and I hope you weren't affected. Sorry to go off topic.
Offline Tony
« Reply #2 on: Mon, 21 February 2011, 23:25:49 »
There's a delay time after a key registers before the keyboard registers another key again, even if the user is holding that key. You can set that delay time in registry.
Here: http://geekhack.org/showthread.php?t=14561
« Last Edit: Mon, 21 February 2011, 23:29:47 by Tony »
Offline regicide
« Reply #3 on: Tue, 22 February 2011, 00:38:31 »
I am actually looking at programming a controller and trying to find out how much of a window I had to 'catch' the key press during, so my question was concerning the switch hardware itself. Sorry if I phrased it poorly.
@keyboardlover thank you for your thoughts, thankfully I am a while away, although we still felt it.
edit: so its NOT SPST? if you hold a key depressed does the switch not stay closed?
« Last Edit: Tue, 22 February 2011, 00:41:31 by regicide »
Offline regicide
« Reply #4 on: Tue, 22 February 2011, 02:53:22 »
Thanks for that ripster
Just found on the spec page the <5ms you quoted.
EDITED sorry dud'd out there for a moment and though not open meant the switch is in a closed state when not pressed, very dud of me >.>
Cheers guys.
« Last Edit: Tue, 22 February 2011, 02:59:24 by regicide »
