Author Topic: Wii keyboard  (Read 3650 times)
Offline poco
Wii keyboard
« on: Mon, 21 February 2011, 23:01:59 »
I found a wired USB keyboard that came with my Wii, and thought I'd give it a try. The model number is KU-0906. It's cute, and the keys don't feel extremely mushy, though they're spaced pretty far apart. Touch typing on them is a bit tricky. Anyways, do you think it's scissor-switch or rubber domes?
Ducky 1087 - MX Black | Leopold tenkeyless - MX Brown
Wii keyboard
« Reply #1 on: Tue, 22 February 2011, 04:14:42 »
I recognize it. It also comes with Acer's Inte Atom-based boxes. I had opened one up to see. Those are not scissor-switches. The key spacing is larger than 3/4" and the keys have rounded edges. 3 mm travel.
One of the most horrible keyboards that I have had to use at work.
Offline poco
Wii keyboard
« Reply #2 on: Tue, 22 February 2011, 10:42:15 »
Quote from: Findecanor;299242
Yeah, typing on it's not exactly a breeze.
