Author Topic: A better nav cluster  (Read 5378 times)
Offline Pylon
« on: Tue, 22 February 2011, 12:52:36 »
The other day at school, I noticed the advantages of the nav layout of the numpad (when numlock is off) - Home, End, Page Up, and Page Down were conveniently located next to the arrow keys, unlike in the dedicated nav cluster, where they were farther away. However, the lack of an inverted T layout was annoying, as it meant that my middle finger had to move extra to press the down arrow.
So I thought about this a little while, and I came up with the following as a better nav cluster:
A lot of laptops place Page Up and Page Down near the arrow keys, and some people markedly prefer this layout. So I basically moved the 2x3 nav block down right next to the arrow keys to make them more accessible. That means that you have easy access to Home/End and Page Up/Page Down when using the arrow keys. I placed Delete above the up arrow and gave it a step to prevent accidental presses when using the arrow keys. And the hated Insert key was removed (you could probably relocate it to a different part of the keyboard).
This arrangement also gets you a bit more space, on the board, so you can fit in three more keys where the 2x3 block used to be. Perhaps volume controls?
Any thoughts?
Offline symphonic1985
« Reply #1 on: Tue, 22 February 2011, 13:00:39 »
I like it. I'm still thinking of how I will arrange the arrow keys for my 180-flip-thumbs-on-f-keys mod. I wouldn't want to lose any of those 9 nav keys but it's true that insert is a little pointless for most of us. Volume controls are a must for me now too, ever since I got used to using a Logitech Illuminated.
Offline itlnstln
« Reply #2 on: Tue, 22 February 2011, 13:02:21 »
I'm not a huge fan of "alternative" layouts, but this looks like a pretty good idea.  I typically use the arrow keys in conjunction with Page Nav keys (Shift+End+Down in Excel, for example), and sometimes that's quite a jump on a regular layout (even worse on the G80-1800, which is the main reason I ended up not liking it).  The HHKB makes this easy, too.
EDIT:  Getting rid of/moving Insert is a great idea, too.  It's pretty worthless, IMO.
« Last Edit: Tue, 22 February 2011, 13:04:39 by itlnstln »
Offline bpiphany
« Reply #3 on: Tue, 22 February 2011, 13:30:53 »
I use insert all the time writing code in a non-looping way =P But mashing the navcluster is either to merge it with the numpad and then there are plenty of keys to keep insert. Or there is a lot of space cleared for more keys in the nav cluster. So either way there will be room. I like the idea in the merge-with-numpad way.
Offline kill will
    • http://www.jerseyshoredailies.com
« Reply #4 on: Tue, 22 February 2011, 14:26:35 »
i prefer the og one ... i like home and end above the up arrow to denote up and down home and end lol
I <3 BS
Offline laden3
« Reply #5 on: Tue, 22 February 2011, 14:38:28 »
A stepped delete is hard to make...
I rrrove brrracks.
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #6 on: Tue, 22 February 2011, 14:41:05 »
I like this, a lot actually.
Quote from: itlnstln;299406
I always accidentally press it while typing or reviewing a paper.  Then all of a sudden, as I'm spacing along, everything gets deleted!  Thank god for CTRL+Z.
Offline Reaif
« Reply #7 on: Tue, 22 February 2011, 15:03:45 »
I like the removal of the Insert key, though I am never a fan of lost functionality lol. I think that it would be pretty awesome to make Insert an alternate function of the Delete key, so that you can use it if you REALLY want to.
Currently own:
Das S Ultimate with Browns
Cherry G84-4100 with ML Linear switches
Memorex Telex with NMB Space Invaders
Leopold with Blues
Offline itlnstln
« Reply #8 on: Tue, 22 February 2011, 15:04:40 »
I used to use a terminal emulator that used Shift+Insert for Paste.  Other than that, it's been since the DOS days (or earlier) since I have used the Insert key regularly.
Offline digitalleftovers
« Reply #9 on: Tue, 22 February 2011, 15:11:02 »
The only issue that I raise with this, is what to do with the space it would leave behind? This config would leave a 2x3 white space.  Do you have any suggestions for what should be done with it?  I'm not opposed to leaving a 1x3 space above and below the cluster, or pushing it to the bottom and leaving the spacing between Psc/ScrLk/Break and the cluster.
Just something to think about.
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline bugfix
« Reply #10 on: Tue, 22 February 2011, 15:16:17 »
Quote from: ripster;299472
This is logical if you are a Happy Hacking Caucasian.
You're from Russia?
*~Unicomp and Topre fan~*
I have:
Unicomp Customizer 105 German
Realforce 105GR
Unicomp Spacesaver German/Ansi hybrid(Current favorite)
I want:
Realforce 88GER
I used to have:
DAS Model S Ultimate EU (Sold)
Offline itlnstln
« Reply #11 on: Tue, 22 February 2011, 15:18:20 »
This is best.
Simple.
Logical.
That's terrible on so many levels.
Offline itlnstln
« Reply #12 on: Tue, 22 February 2011, 15:23:55 »
I don't like nav keys that are commonly used together as layers of the same key.  Even the HHKB doesn't do that.
« Reply #13 on: Tue, 22 February 2011, 15:29:06 »
I am not so sure about the proposed layout. It will not be as easy to find the arrow keys by touch as before. The space in-between the keys provides a guide for the fingers.
Quote from: symphonic1985;299403
I have been thinking about a minimalistic ergo layout with thumb keys ... I am leaning towards using Fn-key (left thumb) + IJKL as arrow keys, with Home/End/PgUp/PgDn around them as on a numpad. The "home row" for a nav cluster is where Left-Down-Right is, so it is natural that if the alphabetic keyboard would be overloaded with arrows, those keys would go onto the alphabetic home row.
This has also a lot to do with me having come accustomed to the numpad on my G80-1800s.
But I am not entirely content with that. I have also been thinking of having arrow keys where the Right Shift key is and letting the other nav keys be combinations of Fn-arrow, but they I would have to move the
In either case, I think that Insert belongs on Fn-Delete ... :-P
Offline theferenc
« Reply #14 on: Tue, 22 February 2011, 15:30:56 »
If you like the inverted T and you like the numpad layout, why not just map down to the 5 key?
Or remap 4/1, 8/5, 6/3 to get almost the layout you have in the OP.
Offline Pylon
« Reply #15 on: Tue, 22 February 2011, 15:58:52 »
So where's your review of that board?
Offline Soarer
« Reply #16 on: Tue, 22 February 2011, 18:23:26 »
Quote from: theferenc;299486
This. Simple, works great, and when you forget that you're on someone elses keyboard, no harm ensues since 5 just does nothing without the remapping.
Otherwise, this 2x4 layout is really nice to use (but doesn't include del)...
Code: [Select]
Home    Up     End    PgUp
Left   Down   Right   PgDn
... and is definately what I'd choose if mapping a second fn layer onto IJKL etc. (or perhaps with pgup/pgdn on Y/H?)
« Last Edit: Tue, 22 February 2011, 18:30:34 by Soarer »
