Author Topic: Ducky DK-9008 Problems  (Read 2854 times)
Offline Denial
« on: Thu, 24 February 2011, 19:29:55 »
I'm having a problem with the top row of keys on my keyboard. Every once in a while the w,r,y,u,p keys stop working. I'm assuming that something got knocked loose inside the keyboard but I can't figure out a way to open the damn thing without breaking the plastic. Anyone else experience this issue or have any idea on how to fix it/open the keyboard so I can look?
Offline Moogle Stiltzkin
« Reply #1 on: Thu, 24 February 2011, 23:41:39 »
I owned both the new G2 and previous dk9008 ducky keyboard, but i never opened it :{
Fsbzz, Rickysio and Squarebox might have however, so you should private message them :}
Anyways i never had that problem, so you might be right that something got knocked loose. My guess maybe the part where it connects the wire to some sort of port inside the back of the keyboard.
Royal Kludge discount code:
Lowyat15
15 USD discount.
Offline imsto
    • imsto.cn
« Reply #2 on: Fri, 25 February 2011, 07:29:53 »
use something to pry the position as the pic showed.
imsto.cn
imsto's AiKB Taobao Shop
IBM Model M*3, IBM M13,M5, IBM with balls.Cherry   3000  3494 3700 4100*6 700*2 11900 8113 DAS4 TG3 KBC PokerDucky09Ducky1087 apple pink alps Ducky bull,tiger,rabbit,dragon version No:0000002
Offline sixty
    • http://deskthority.net
« Reply #3 on: Fri, 25 February 2011, 07:38:46 »
There is not much that can "go loose" in a mechanical keyboard. Most likely a solder joint broke or worse, the PCB cracked.
