Author Topic: Making a split keyboard out of a regular keyboard in software  (Read 3820 times)
Offline dotancohen
    • Dotan Cohen
« on: Tue, 01 March 2011, 14:27:35 »
Any therapist will tell you that your hands should be shoulder-width apart when you type. Sounds great, until you try looking for a keyboard that is shoulder-width wide. Therefore I came up with this keyboard layout to fake it:
http://dotancohen.com/eng/noah_ergonomic_keyboard_layout.html
The current version is based on QWERTY, but I plan on publishing a Colemak version later this week.
I haven't actually yet typed on it, my Kubuntu box is giving me a hard time in configuring any new layouts. So if someone spots anything wrong in the configuration file, or knows how to get it working in Kubuntu 10.10, or types on it and has any feedback, I'd love to know. Thanks!
Offline Tony
« Reply #1 on: Tue, 01 March 2011, 20:48:54 »
Split keyboards specifically change the angle between wrists. On normal keyboards moving a few keys farther apart do not achieve that objective.
« Last Edit: Tue, 01 March 2011, 20:54:56 by Tony »
Offline wanabe
« Reply #2 on: Tue, 01 March 2011, 20:54:39 »
I think the main objective was to have a wider "stance" on the keyboard.  interesting idea, but not sure that I could get used to it
Offline bpiphany
« Reply #3 on: Tue, 01 March 2011, 22:49:08 »
Separating the hands straightens the wrist a little, which is good. Also the arms are turned further apart instead of just the wrists straightening as with angled keyboard halfs. This shouldn't be a big problem if the rotators in your shoulders are not way off what they should be like. This layout is an improvement although perhaps not as much as a truly split keyboard.
Offline dotancohen
    • Dotan Cohen
« Reply #4 on: Thu, 03 March 2011, 10:32:49 »
The goal is not to truly replace a split keyboard, but rather make using a non-split keyboard as comfortable as the hardware will allow without a saw, epoxy, wiring, and conductive glue. I probably should have used a more conservative title.
Any ideas for improvement? What _really_ bothers some of the more fastidious typers here about QWERTY or other layouts?
Offline Ekaros
« Reply #5 on: Sat, 05 March 2011, 21:15:41 »
So 2 HHKBs isn't an option? ;D
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline dotancohen
    • Dotan Cohen
« Reply #6 on: Sun, 06 March 2011, 03:27:58 »
Quote from: Ekaros;305976
At my college I once tried typing with two USB keyboards. It went pretty well, but I had a hard time finding F and J after using the number keys.
Offline sordna
« Reply #7 on: Thu, 21 April 2011, 17:59:01 »
Nice idea! But I think the left hand's stagger problem remains. I think remapping the left side keys in software so the columns lean to the right, will allow you to have your elbows wider apart while still maintaining straight wrists better than just separating the hands by a couple of keys while maintaining the asymmetric left hand stagger.
EDIT: Wow, Ripster has already done what I was talking about, what do you think of making the stagger symmetrical ?
Source: http://geekhack.org/showthread.php?8288-Why-are-keyboard-keys-skewed&p=146411&viewfull=1#post146411
« Last Edit: Thu, 21 April 2011, 23:12:16 by sordna »
Offline dotancohen
    • Dotan Cohen
« Reply #8 on: Fri, 22 April 2011, 13:59:49 »
I love the idea, Sordna. However, I think that simply retraining my fingers to hit the different keys (such as hitting R with the middle finger) would work just as well, save for Q. Furthermore, as my target keyboard layout has a wide Left Shift key instead of squishing the \ key next to it, the idea would require me to move the QWERTY row over two keys. That is quite a tradeoff!
I do agree with the retraining of the hands, however, as I do see that it is pushing my whole left hand into a better position. Thanks for the tip!
