Author Topic: Black SiiG Microtouch "mechanical" is ALPS?  (Read 2702 times)
Offline ricercar
  • mostly abides
« on: Fri, 04 March 2011, 23:09:29 »
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=190446909477&ssPageName=STRK:MEWAX:IT
•High-quality key switches for the click and feel typists prefer
- Switch mechanism: Mechanical-key switch
- Key switch life: 20 million cycles
•High-quality key switches for the "click" and "feel" that typists prefer
« Last Edit: Fri, 04 March 2011, 23:11:47 by ricercar »
Offline elbowglue
« Reply #1 on: Sat, 05 March 2011, 00:11:57 »
Quote from: ricercar;305342
This is rubber domes if I am not mistaken.
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline wanabe
« Reply #2 on: Sat, 05 March 2011, 00:54:48 »
i dont know from experience, but many people will tell you that these are rubber domes
Offline REVENGE
« Reply #3 on: Sat, 05 March 2011, 09:45:23 »
From MacMall:
Key Features and Benefits:
– Light-weight, space-saving design is ideal for notebook computer or space-limited environments
– IBM AT and PS/2 enhanced 101/102-key keyboard compatible
– PC/AT 5-pin DIN keyboard connector
– Separate Scroll Lock, Num Lock, and Caps Lock LED indictor
– Embedded numeric keypad with cursor-and screen-control capabilities
– Special "Fn" key for accessing the cursor- and screen-control keys, F11 and F12 key functions, and embedded numeric keypad
– Two "Ctrl" and "Alt" keys, one on each side for convenience
– High-quality keyswitches for the "click" and "feel" that typists prefer
– Standard QWERTY keyboard layout
– Snap-open legs for height adjustment
Detailed Specs:
– Version: v1
– Description: Enhanced 80-key mini-size PC Keyboard
– Compatibility: IBM AT and PS/2 enhanced 101/102-key keyboard compatible
– Regulatory approval(s): FCC Class B: E5X5R5BTC-5100C
– Electrical Characteristics:
Input power: + 5V DC
– Switch activation mechanism: Conductive rubber
– Physical & Mechanical Characteristics
– Connector type: AT (5-pin DIN)
– Number of keys: 80
– Key switch life: 20 million cycles
Offline chimera15
« Reply #4 on: Sat, 05 March 2011, 13:16:59 »
Tired of seeing these threads.   There are several of them from the time I've been here.  Anything that says "plus" is rubber dome.   This is an old problem.  Many sellers use the description of the old minitouch for the plus which causes confusion.
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline REVENGE
« Reply #5 on: Sat, 05 March 2011, 13:48:57 »
Quote from: chimera15;305616
To ricercar's credit, this seller seems to have omitted the part about the rubber membrane. :crazy:
