Author Topic: ps/1 and ps/2  (Read 1618 times)
Offline obj-c
ps/1 and ps/2
« on: Sat, 05 March 2011, 12:07:30 »
what is the difference between these two types of ports?
Offline rustybarnacle
ps/1 and ps/2
« Reply #1 on: Sat, 05 March 2011, 12:11:17 »
Ps2 you can find on modern hardware?
Offline Surly73
ps/1 and ps/2
« Reply #2 on: Sat, 05 March 2011, 12:32:55 »
I haven't checked any references, but having been a computer user back when PS2 was invented I'm not so sure there is a PS1 connector.  There was a PS/1 computer line from IBM, as well as a PS/2.  The connector launched on the PS/2 is foreverafter referred to as the "PS/2" connector.  I think it used to be called the "PS/2 style connector".
The connector is named for the computer it was first found on, it isn't a name which was originally given to the connector itself.  AFAIK.  So if I were to rephrase the answer the way some others here at GH: "The difference is that the PS2 connector exists".
« Last Edit: Sat, 05 March 2011, 12:36:48 by Surly73 »
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
ps/1 and ps/2
« Reply #3 on: Sat, 05 March 2011, 15:48:56 »
Quote from: Surly73;305591
This.
Before that, PC keyboards used 5-pin DIN connectors (easily adapted to PS/2 for anything that speaks at least the AT keyboard protocol), same as used for MIDI or older European audio components.
