Author Topic: USB detachable - pins usb socket - need help  (Read 2720 times)
Offline CeeSA
« on: Sun, 06 March 2011, 09:02:51 »
i need some help from you guys.
otherwise i go nuts....
i would like to make my keyboards usb detachable. sounds pretty easy.
i use this:
Backside with 4 pins:
i got 4 cables from the usb keyboardcable:
black - ground
red - 5V
white - data -
green - data +
and i got 4 pins.
but how is the occupancy?
reading this side:http://de.wikipedia.org/wiki/USB
i try
white up left
red up right
green down lift
black down right
as the pic shows.
and other combinations, nothing works correct....
thanks for reading and hopefully helping.
##### done #######
this is correct:
Pin 1 - VBUS - RED
Pin 2 - D- - WHITE
Pin 3 - D+ - GREEN
Pin 4 - GND - BLACK
« Last Edit: Sun, 06 March 2011, 09:20:01 by CeeSA »
Offline CeeSA
« Reply #1 on: Sun, 06 March 2011, 09:22:08 »
believe i read the mod, but i did not get it - i am old :/
thank you anyway modgod ripster :)
