Author Topic: Keyboard wobble  (Read 1862 times)
Offline Lpb45
Keyboard wobble
« on: Sun, 06 March 2011, 17:02:15 »
So I just got a Filco tenkeyless from AG, and after using it for about a day I noticed that it tends to wobble when I have it laying flat.  I am going to try and put some filler on the end of one of the feet that seems to be shorter then the rest causing it to wobble.  Any Ideas of what would be a good choice for material for doing this?
Any help would be much appreciated!
Topre - 86U   |   Filco - Tenkeyless Linear Red
Filco - Tenkeyless Blue       |   Filco - Fullsize Non NKRO Blue (Work)
Offline RiGS
Keyboard wobble
« Reply #1 on: Sun, 06 March 2011, 17:05:50 »
Just take your time. This is a common problem with new Filcos.
Offline Armando Penblade
    • http://thegeekery.org
Keyboard wobble
« Reply #2 on: Sun, 06 March 2011, 19:24:36 »
http://www.amazon.com/Type-AC30272-60-Custom-Trim-Non-Slip/dp/B001PRPBC4
You want this, but not from Amazon. Buy it at your local big box retailer like Walmart or Target; it's usually in the kitchen section near cutting boards and utensils. You'll also find higher grade stuff in the tools section near toolboxes, if it needs to be a little bit thicker and more durable. Easy to cut, long-lasting, and very "non-slip."
Of course, it's also ugly as sin ;)
Filco Majestouch 104-US, Metallic Blue, with Chery MX Blues  //  Microsoft Comfort Curve 2000, 104-US + Media Keys & Browser Controls  //  iRocks RF-6570 Cordless 104-US, 2.4GHz Wireless, White  //  SteelSeries 6Gv2 104-US, Black, with Cherry MX Blacks
Offline Lpb45
Keyboard wobble
« Reply #3 on: Sun, 06 March 2011, 19:39:10 »
wow ripster, lol it actually did straighten it out no wobble at all now. horray!!
Is this just like qc thing that happens with alot of boards?
Offline Lpb45
Keyboard wobble
« Reply #4 on: Sun, 06 March 2011, 19:41:27 »
armando,
ya I was going to go looking for something like that in my closet and just cut up a small strip and super glue it to the foot pad.  twisting the board just a bit worked perfectly though, it was just a very very small wobble but it was bugging me like crazy because I had to put the back feet up to get it to sit straight.
Offline BababooeyHTJ
Keyboard wobble
« Reply #5 on: Sun, 06 March 2011, 19:42:32 »
Quote from: Lpb45;306481
I'm glad that you started this thread. I was having the same problem with my ducky. That fixed it for me too.
Thanks ripster.
