Author Topic: Key/Case Yellowing  (Read 1509 times)
Offline BlackFalcon448
Key/Case Yellowing
« on: Mon, 07 March 2011, 17:25:51 »
Hey guys, I think I am posting this in the right section. Anyway I recently acquired an AEKII and noticed that the space bar and upper case are yellowed. I was wondering if there was an way to safley remove the discoloring or if i will just have to deal with it. It's kind of hard to tell by the pics, but it's much more pronounced in person.
P.S. I got the keyboard with a power macintosh 7600/132 which has much worse yellowing. If has the same type of plastic maybe I could clean it in the same way...?
Pics here:
I couldn't figure out how to upload pics directly to geekhack, so I hosted them on tinypic.
Key/Case Yellowing
« Reply #1 on: Mon, 07 March 2011, 18:16:17 »
Quote from: ripster;307180
RetrObrite instructions here.
Wow! Thanks for that link.
Offline Peter
Key/Case Yellowing
« Reply #2 on: Tue, 08 March 2011, 12:23:42 »
'Clairoxide', that's a Hairdressers-product right ?
It may contain, for key-caps and hairdressers, undesirable chemical additives AFAIK .
The recommendation is to use min 10-14% hydrogen-peroxide, however it may be problematic
to find it these days as it can apparently be used by Al-Cracker to produce exploding shoes and underwear ..
If you do find it : WEAR GOGGLES AND CHEMICAL GLOVES !!
I **** you not, this stuff eats your skin and/or eyes !!
« Last Edit: Tue, 08 March 2011, 12:30:32 by Peter »
