Author Topic: ...Shakes fist at leaky ceiling!  (Read 2327 times)
Offline synack
« on: Mon, 07 March 2011, 20:58:22 »
So at my work there was a major water leak on the third floor -- which apparently lasted for hours (nobody was in the area on the weekend.)  It ended up partially leaking down into my basement office, spritzing my RK-9000!  :mad:
Doesn't look there was any damage.  Judging from the dried water pattern on the desk it wasn't much water;  Literally a sprinkle pattern.  I'm still annoyed nonetheless.
Definitely makes me wish I had a hood of some kind.  That, and also wishing that Filco-like boards had drain holes like a Lexmark/Unicomp M...
...Just needed to vent...
Offline keyboardlover
« Reply #1 on: Mon, 07 March 2011, 21:01:03 »
You're the second person I've seen on here venting about this kind of thing. Ceiling leaks have happened at my place before...I'm a bit worried about my 87U!
Offline synack
« Reply #2 on: Mon, 07 March 2011, 21:18:22 »
What's really funny about it is that replacing work supplied three monitors and two PCs would be no problem whatsoever.  (And fast, I'd just pilfer the storage room.)  But I bet a $100 reimbursement for the keyboard would be a hard sell...
