Author Topic: MX Xxxxx key caps  (Read 17531 times)
Offline Ekaros
MX Xxxxx key caps
« on: Tue, 08 March 2011, 14:26:58 »
Wondered about this, a way to mark your boards fast and clearly ;D
So either MX letters or
Black on mx-blue stem colored key:
MX
Blue
White? on mx-black stem colored key:
MX
Black
White(or something else, black is too dark for brown) on mx-brown stem colored key:
MX
Brown
Black on mx-red stem colored key:
MX
Red
Black on mx-white stem colored key:
MX
Clear
Would get these if I get someone to compare the samples with stems. About 20 packets, 5 keys each, 3-5$ for all+shipping...
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline 7bit
  • MX1A-G1DW
MX Xxxxx key caps
« Reply #1 on: Tue, 08 March 2011, 14:31:13 »
Nice idea, but why not using clears, so you can see the color of the stems ...
ps: sorry.
Please use these order-ID-s:
MXBLUE
MXBLACK
MXBROWN
MXRED
MXCLEAR
price is $0.4 per key, if 25 are produced.
« Last Edit: Tue, 08 March 2011, 14:46:24 by 7bit »
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline Ekaros
MX Xxxxx key caps
« Reply #2 on: Tue, 08 March 2011, 14:43:53 »
Hmm, there's and idea too ;D
[SIGPIC][/SIGPIC]
Offline Ekaros
MX Xxxxx key caps
« Reply #3 on: Tue, 08 March 2011, 17:02:48 »
No luck it seems, likely need to pass this idea...
[SIGPIC][/SIGPIC]
Offline gohu
MX Xxxxx key caps
« Reply #4 on: Wed, 09 March 2011, 16:07:36 »
I got an invoice recently and... am I really the *only* one to have voted for some of those?
Offline Ekaros
MX Xxxxx key caps
« Reply #5 on: Wed, 09 March 2011, 16:15:34 »
Quote from: gohu;308703
Yes, just gauging intrest. Don't know if anyone realy want these or sense for me to do larger order and resell...
[SIGPIC][/SIGPIC]
Offline 7bit_vote
Off for holly days until Sunday 20th March 2011!
« Reply #6 on: Thu, 10 March 2011, 09:44:00 »
I'm off for holly days until Sunday 20th March 2011!
The vote-system will work without me. Just send your order lists to me, 7bit_vote.
You will get some statistics from time to time.
Don't ask 7bit or me any questions during that time. We will not answer!
There will be no update of payment status. Anybody should keep track of that themselves! It is sufficient to pay when I'm back again.
For questions, please read the first post in the main thread.
Have a lot of fun ...
Offline 7bit
  • MX1A-G1DW
MX Xxxxx key caps
« Reply #7 on: Thu, 24 March 2011, 07:13:30 »
I need the color codes for some of these keys:
MXBLUE   BO (Blue) ???
MXBLACK   NN (Black)
MXBROWN <---- we had no brown so far ...
MXRED   RA (Red)
MXCLEAR <--- clear is not possible
Offline Ekaros
MX Xxxxx key caps
« Reply #8 on: Thu, 24 March 2011, 07:25:04 »
Quote from: 7bit;317556
MXBLACK   NN (Black)
MXRED   RA (Red)
Hmm, Clear is some near white and Brown, I would aim near the MX-stems. That was my original idea on these...
[SIGPIC][/SIGPIC]
Offline Ekaros
MX Xxxxx key caps
« Reply #9 on: Thu, 24 March 2011, 18:17:37 »
TGH for brown?
Also, can't quite make out what would be right for those clears. There is a few white options, anyone wanna go and decide?
[SIGPIC][/SIGPIC]
Offline 7bit
  • MX1A-G1DW
MX Xxxxx key caps
« Reply #10 on: Fri, 25 March 2011, 08:37:55 »
Quote from: Ekaros;317993
TGH for brown?
Did you ask sixty?
I would recommend a dirty white. It must be a white which is not yellow at all, more into the blue direction. A cold white ...
You've got 6 hours left!
Otherwise ...
Offline Fwiffo
MX Xxxxx key caps
« Reply #11 on: Fri, 25 March 2011, 08:58:56 »
There's UK-11 which is colorless translucent, which is basically what MX Clear keystems are. If that can't be used, BFM is a very pretty blue-white. WA, WFK, and WCK are your other whites and off-whites. I think WA has the bluest cast, but it might be too white. Maybe WQ?
You can call me... Keyboard Otaku... or not quite...
Offline 7bit
  • MX1A-G1DW
MX Xxxxx key caps
« Reply #12 on: Fri, 25 March 2011, 12:02:15 »
Quote from: Fwiffo;318334
I;'m not sure if it works with double shots. At least the clear plastic does not work. I will ask about it ...
Offline Ekaros
MX Xxxxx key caps
« Reply #13 on: Fri, 25 March 2011, 14:56:26 »
Quote from: 7bit;318416
UK-11 would be best, if not someone which is near to it.
[SIGPIC][/SIGPIC]
Offline LivingChampion
MX Xxxxx key caps
« Reply #14 on: Mon, 04 April 2011, 15:52:31 »
Quote from: 7bit;307856
ps: sorry.
MXBLUE
MXBLACK
MXBROWN
MXRED
MXCLEAR
Where can I get them for that price?
Offline Ekaros
MX Xxxxx key caps
« Reply #15 on: Mon, 04 April 2011, 16:33:03 »
Quote from: LivingChampion;324489
No where, if you don't order 25 in next order...
[SIGPIC][/SIGPIC]
