Author Topic: Taobao help: Improved Noppoo Choc Mini 84?  (Read 11577 times)
Offline AmigaDisk
  • Formerly ohm-ish
« on: Tue, 08 March 2011, 20:12:32 »
It looks like this http://item.taobao.com/item.htm?id=9025172863 is an improved version of the Noppoo Choc Mini 84
But I can't figure out if the item is actually an improved version or if they just advertise it's coming..
The top picture is brown/grey on black keys. The other pictures shows white on black
Can someone understand it?
Offline keyboardlover
« Reply #1 on: Tue, 08 March 2011, 20:13:55 »
Can't. Stop. Looking at your avatar.
Sorry, what was this thread about?
Offline AmigaDisk
  • Formerly ohm-ish
« Reply #2 on: Tue, 08 March 2011, 20:16:35 »
Quote from: keyboardlover;308164
hehe
Keyboards, you know?
« Reply #3 on: Tue, 08 March 2011, 20:19:31 »
Only difference I can see from the photos is the key lettering looks different - more white.
Offline calavera
« Reply #4 on: Tue, 08 March 2011, 20:30:50 »
They made it look like double shots with brighter fonts for contrast. But they're laser engraved aren't they?
Offline REVENGE
« Reply #5 on: Tue, 08 March 2011, 20:56:58 »
Translation from a pinyin translation via Google:
"NOPPOO Choc Mini 84 keyboard, improved edition is just the uniformity of the font and lettering, they're all laser engraved
Black and blue switched priced at 399, brown switched priced at 469
POM key caps, laser engraved
USB n-key rollover [completely free of conflict] design
Multimedia, Win-key locking
Key caps and layout equivalent to Cherry 3000 series, interchangeable
However, we don't recommend pulling key caps, key caps are rather tight, it's easy to break key stems!"
EDIT: Actually the direct English translation is pretty good in this case.
« Last Edit: Tue, 08 March 2011, 20:58:59 by REVENGE »
Offline p.s.
« Reply #6 on: Tue, 08 March 2011, 22:02:32 »
i can read simplified Chinese but i don't have a original noppoo,
i cant tell the difference between them.
my vendor sub-forum for  selling all KBC, KBT, Vortex prodcuts: http://geekhack.org/index.php?topic=34366.0
Offline cbf123
« Reply #7 on: Tue, 08 March 2011, 23:17:37 »
There's a whole series of shots like that over at cuteoverload.com.  Just look for the ones tagged "Cats 'n' Racks".
Here's the original:
Daily drivers are:
Microsoft Natural (the original, and still going strong)
Microsoft Natural Elite
Offline calavera
« Reply #8 on: Tue, 08 March 2011, 23:19:05 »
Pulling key caps not recommended?? Hell, the first thing I would have done was switch out the key caps if I had bought one. :P
Offline Orphagn
« Reply #9 on: Wed, 09 March 2011, 00:14:47 »
Hopefully the lettering doesn't rub off as quick as the first version did.
Keyboards:
KBC Poker
Cherry G80-11900
Cherry G80-3494
Offline manfaux
« Reply #10 on: Wed, 09 March 2011, 00:19:32 »
Those pictures in the taobao listing you provided are just some "spy shots" prior to the actual choc mini release. Neither the original Choc Mini nor the newer version looks like that.
It says it's indeed the new "improved version" and it's most likely true, they have already halted the production on the old model a while ago, every choc mini shipped since January has been the newer version.
They've changed two things on the new Choc Mini:
1. The letter printing on scrolllock, switchlock, and capslock keycaps are revised to match the rest of the keycaps.
2. thinner wire stabilizer under space bar. (Because some had reported that the older space bar had problems bouncing back to its unpressed position due to the thickness of that stabilizer wire).
« Last Edit: Wed, 09 March 2011, 00:21:46 by manfaux »
Offline db_Iodine
« Reply #11 on: Wed, 09 March 2011, 01:17:16 »
Quote from: Orphagn;308283
Haven't seen anyone with this problem, including myself.
[SIGPIC][/SIGPIC]
Offline RiGS
« Reply #12 on: Wed, 09 March 2011, 08:39:53 »
I think they also fixed shift and enter.
Offline CeeSA
« Reply #13 on: Wed, 09 March 2011, 08:50:04 »
i would love a white version.
a version with doubleshots would also welcome
Offline MF_
« Reply #14 on: Wed, 09 March 2011, 11:15:50 »
That is hawt.
Offline flyinout
« Reply #15 on: Fri, 11 March 2011, 00:43:04 »
Although this may be the new version, I still do not recommend you buy from this seller whose reputation rating is lower than the average.(on the right side of that page)
[SIGPIC][/SIGPIC]
Filco tenkeyless Brown.Razer Deathadder 3500[/SIZE]
Offline sickchief
« Reply #16 on: Fri, 11 March 2011, 03:20:27 »
I believe there is only one version ever available on the market, that is the 'improved' version. The one with brighter lettering keycaps is a prototype to my knowledge.
Offline db_Iodine
« Reply #17 on: Fri, 11 March 2011, 03:50:57 »
Quote from: sickchief;309783
I'd rather call it the first revision and the current model second revision.
[SIGPIC][/SIGPIC]
Offline dracaXL
    • http://www.technickal.org
« Reply #18 on: Fri, 11 March 2011, 06:30:46 »
The first revision still has NKRO over USB, iirc?
Filco Majestouch Linear (i.e. MX Blacks) | Noppoo Choc Mini (MX Browns) | TVS Gold Bharat (MX Blue) | VorTex KBC Poker* (MX Red)
Intel Core i7-2600k | Gainward GTX 580 GOOD | 8GB XMS3 DDR3 RAM | Gigabyte P67-UD4 | Asus Xonar Essence ST | NZXT Phantom | KRK RP5 G2 w. Wharfedale SW150
*pre-ordered
Offline db_Iodine
« Reply #19 on: Fri, 11 March 2011, 07:36:11 »
Quote from: dracaXL;309822
Yes. fssbzz bought the first revision and made a review of that.
[SIGPIC][/SIGPIC]
Offline manfaux
« Reply #20 on: Fri, 11 March 2011, 15:06:25 »
No, like db_iodine said, tons of people bought the first version, go to the review section.
Offline aming
« Reply #21 on: Sat, 12 March 2011, 11:19:33 »
All the noppoo mini available is the 2nd edition which is so call "Improved version in the taobao". The 2nd edition is debut in the early of the 2011.
Offline Laggy-gaga
« Reply #22 on: Sat, 12 March 2011, 11:24:23 »
I asked one of the sellers
he said the only improvement is noppoo changes the color of three function keycaps (which were ink printed)on the top of right as same as the rest of keycaps, now the new version mini keycaps are all laser printed.
images can be seen here:
old version:
new version:
« Last Edit: Sat, 12 March 2011, 11:26:40 by Laggy-gaga »
Working: Ducky Dragon Blue
Looking for: 356L
For sale:Benchmark DAC1+Stello U3+Amber,RS1i,GS1000i,HE400,HD650,w4r,se535LE
AU only
Offline db_Iodine
« Reply #23 on: Sat, 12 March 2011, 11:27:17 »
Quote from: aming;310469
Must have been really early January since I ordered mine on December 31st and got the "second revision" keyboard.
[SIGPIC][/SIGPIC]
Offline Laggy-gaga
« Reply #24 on: Sat, 12 March 2011, 11:30:15 »
The space key could be changed so how as well, but I can't be sure.
Looking for: 356L
AU only
Offline aming
« Reply #25 on: Sat, 12 March 2011, 11:37:20 »
Actually, what do you want the most feature in the next version of Noppoo Mini?
Offline kriminal
« Reply #26 on: Sat, 12 March 2011, 21:36:55 »
meh they have a disclaimer over pulling keycaps.. big lost of interest there for me..
« Last Edit: Sat, 12 March 2011, 21:40:15 by kriminal »
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
Offline Art of Payce
« Reply #27 on: Thu, 31 March 2011, 23:07:01 »
I see volume up/down, fwd/rev, and close window multimedia FNs. Why isn't there a press/play FN? Also, I'd like to see the num pad include a division key. The addition (+) is covering up the (?, /) key. Lastly, I wish the backside stands had rubber or something to grip the ground better to keep the board from moving. I like everything else.
Offline aming
« Reply #28 on: Fri, 01 April 2011, 04:00:50 »
I will told your comment to the Noppoo. And I would like know how many ppl will have interest if Noppoo debuts a Topre Keyboard?
Offline CeeSA
« Reply #29 on: Fri, 01 April 2011, 04:26:12 »
i would like to have alternate keycaps with doubleshots.
also a complete white version would be nice.
instead of a topre version first it should be a version  with cherry mx red.
Offline speakeasy
« Reply #30 on: Fri, 01 April 2011, 04:43:02 »
Quote from: aming;322575
If they can do it for a low price like the choc mini, sure.
[sigpic][/sigpic]
PiaNoppoo Choc Mini 茶轴
PUNCH THE KEYS FOR GOD\'S SAKE!
