Author Topic: The pedantic hacker keyboard - oops  (Read 5005 times)
Offline regicide
  • Software developer and Open source hacker
« on: Thu, 10 March 2011, 01:56:01 »
I thought I was posting this to the modification sections... this can now be found here: http://geekhack.org/showwiki.php?title=Island:16103
Sorry guys >.>
« Last Edit: Thu, 10 March 2011, 03:19:22 by regicide »
2 Kinesis advantages (MX browns)
Offline kill will
    • http://www.jerseyshoredailies.com
« Reply #1 on: Thu, 10 March 2011, 02:05:09 »
i dont know how you guys type on anything but qwerty.  it took me like 3 seconds to find where g was.
I <3 BS
Offline Ascaii
« Reply #2 on: Thu, 10 March 2011, 02:55:01 »
I find your escape placement personally weird...but I'm happy to see someone using the marquardt heros arrow placement.
Offline regicide
« Reply #3 on: Thu, 10 March 2011, 03:18:11 »
This was honestly meant to be in the modifications forums... idk how the hell I managed to put it here >.>
You can now find it at: http://geekhack.org/showwiki.php?title=Island:16103
Can admin please close / lock / ignore this thread?
Quote from: Ascaii;308958
I'm a Vim user, so I use escape A LOT and caps lock is a waste. The original plan was to have Ctrl there, but then I switched from emacs to vim....
marquardt arrow placement? Never heard of it nor used it... Just thought it would be a better usage of the space, and considering I already use hjkl for moving around in vim and my window manager the same layout but dedicated to arrows seemed to be a good idea... yay for reinventing the wheel.
Offline regicide
« Reply #4 on: Thu, 10 March 2011, 03:22:06 »
Quote from: kill will;308944
I still use qwerty for my day to day life.. learning a new keyboard layout is a slow and painful process >.>
Although I do type on a blank keyboard anyway, I just cant afford to just jump into dvorak due to the loss of productivity (I'm a student / open source programmer / gamer) >.>
So I use dvorak when I can, but type things like this in qwerty, hence the switch: that way I can use dvorak all the time, and if typing gets difficult swap to qwerty without having to close my application, change settings, possibly reboot, etc.
Offline Surly73
« Reply #5 on: Thu, 10 March 2011, 07:14:57 »
Eeek.  So this modified-Dvorak layout which has never been seen before is going to come with blank keycaps?  That's a heck of a learning curve.  Seems more like a lottery whether you get the character you were hoping for.
Offline regicide
« Reply #6 on: Thu, 10 March 2011, 14:54:13 »
Quote from: Surly73;309042
Hahaha it does seem a little daunting doesnt it...
But it will have a switch to toggle between dvorak and qwerty, but in either layout the only difference is the alphabetical keys, the others will remain in their spots :)
The alphanumeric keys are all pure dvorak, the only modifications is the caps lock becoming an escape, the lower modifiers (Which I dont use) becoming arrows and hiding other functionality in a second layer over 'obvious' keys (seems obvious to me, fn 1 becomes f1, fn up becomes pg up, etc.)
« Last Edit: Thu, 10 March 2011, 14:58:29 by regicide »
Offline Ekaros
« Reply #7 on: Fri, 11 March 2011, 10:10:19 »
On layout, standard QWERTY signaling is an option? So can do custom-layout also on the OS end...
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline regicide
« Reply #8 on: Sat, 12 March 2011, 02:09:34 »
Quote from: Ekaros;309891
Well there will be a hardware layout to switch between two layouts (currently qwerty and dvorak for the alphanumeric keys). However the two layouts are really just arrays of character codes, so on the firmware you could make it any two layouts (affected any of the keys), but if its in qwerty mode then yes the OS could remap the keys.
