Author Topic: Macintosh Plus Keyboard (M0110A) : to usb with teensy HELP  (Read 4014 times)
Offline b0bb3r5
« on: Sat, 12 March 2011, 14:32:02 »
here is some info on the keyboard i found
Macintosh Plus Keyboard (M0110A):
   Introduced and included with the Macintosh Plus in 1986, it was an extended keyboard that had a built-in numeric keypad. In 1987 it was updated to Apple's new Platinum gray color. It continued to use the telephone-cord style connector to the CPU and was interchangeable with the M0110. Though Apple switched all other keyboards to Apple Desktop Bus connectors by this time, this keyboard was manufactured unchanged for 4 more years until the Plus was discontinued in 1991.
Data port:
The Macintosh 128K, Macintosh 512K and Macintosh Plus from Apple used 4P4C connectors to connect the keyboard to the main computer housing. The connector provided power to the keyboard on the outer two conductors and received data signals on the inner pair. The cable between the computer and the keyboard was a coiled cord with an appearance very similar to a telephone handset cable.[6] The connector wiring, however, required a polarized straight through pinout. Using a telephone handset cable instead of the supplied cable could short out the +5 volt DC supply and damage the computer or the keyboard.[7]
Some consumer equipment such as DirecTV set top boxes include a 4P4C low-speed data port connector.[5] Such connectors can be adapted for use with a computer's serial port so that control commands can be sent from the computer to the set top box.
how would i go about converting the signal to usb with a teensy and is this a "AT Keyboard" ?
http://en.wikipedia.org/wiki/AT_keyboard
Offline kps
« Reply #1 on: Sat, 12 March 2011, 19:09:59 »
Quote from: b0bb3r5;310607
It's not an AT keyboard in any way.
The primary documentation for the early Mac keyboard protocol is in the original Inside Macintosh, Volume III. I won't link to this for copyright reasons but you won't have any trouble finding it.
Some documentation is also available at kbdbabel, particularly on the signalling and pinout pages, and in the code of the 8051-based Mac-to-PS/2 adapter. Keep in mind that kbdbabel numbers bits backwards from Apple, which can be confusing.
Here is a table of Mac keyboard codes, with the equivalent USB code:
Code: [Select]
--------------- Macintosh -----------------------------------------------------
Code          kbdbabel
US  Int'l     (reverse)     USB   Description
01   01        80            04    a and A
03   03        C0            16    s and S
05   05        A0            07    d and D
07   07        E0            09    f and F
09   09        90            0B    h and H
0B   0B        D0            0A    g and G
0D   0F        B0            1D    z and Z
0F   11        F0            1B    x and X
11   13        88            06    c and C
13   17        C8            19    v and V
15   15        A8            --
17   5B        E8            05    b and B
19   19        98            14    q and Q
1B   1B        D8            1A    w and W
1D   1D        B8            08    e and E
1F   1F        F8            15    r and R
21   21        84            1C    y and Y
23   23        C4            17    t and T
25   25        A4            1E    1 and !
27   27        E4            1F    2 and @
29   29        94            20    3 and #
2B   2B        D4            21    4 and $
2D   2D        B4            23    6 and ^
2F   2F        F4            22    5 and %
31   31        8C            2E    = and +
33   33        CC            26    9 and (
35   35        AC            24    7 and &
37   37        EC            2D    - and _
39   39        9C            25    8 and *
3B   3B        DC            27    0 and )
3D   3D        BC            30    ] and }
3F   3F        FC            12    o and O
41   41        82            18    u and U
43   43        C2            2F    [ and {
45   45        A2            0C    i and I
47   47        E2            13    p and P
49   55        92            28    Return (ENTER)
4B   4B        D2            0F    l and L
4D   4D        B2            0D    j and J
4F   4F        F2            34    ' and "
51   51        8A            0E    k and K
53   53        CA            33    ; and :
55   --        AA            31    \ and |
57   5F        EA            36    , and <
59   15        9A            38    / and ?
5B   5D        DA            11    n and N
5D   57        BA            10    m and M
5F   59        FA            37    . and >
61   61        86            2B    Tab
63   69        C6            2C    Spacebar
65   49        A6            35    ` and ~
67   67        E6            2A    Backspace
69   63        96            58    Enter (KP)
6B   6B        D6            --
6D   6D        B6            --
6F   6F        F6            E2    Left Alt
71   71        8E            E1    Shift
73   73        CE            39    Caps Lock
75   75        AE            E0    Left Control
77   77        EE            --
79   79        9E            --    Keypad prefix
7B   7B        DE            --
7D   7D        BE            --
7F   7F        FE            --
--   0D        AA            64    \ and | (Non-US)
--   65                      32    § and ± (Non-US)
--------------- Keypad --------------------------------------------------------
Prefixed by 0x79 (kbdbabel 9E).
Code          kbdbabel
03   03        C0            63    .
05   05        A0            4F    Cursor Right
0D   0D        B0            50    Cursor Left
0F   0F        F0            53    Clear
11   11        88            51    Cursor Down
19   19        98            58    Enter
1B   1B        D8            52    Cursor Up
1D   1D        B8            56    -
25   25        A4            62    0
27   27        E4            59    1
29   29        94            5A    2
2B   2B        D4            5B    3
2D   2D        B4            5C    4
2F   2F        F4            5D    5
31   31        8C            5E    6
33   33        CC            5F    7
37   37        EC            60    8
39   39        9C            61    9
--------------- Mac Plus ------------------------------------------------------
Prefixed by 0x71 0x79 (and/or 0x79 0x71 ?), according to kbdbabel.
(kbdbabel: 9E 8E)
Code          kbdbabel
05   05        A0            55    Keypad *
0D   0D        B0            57    Keypad +
11   11        88            53    Keypad Clear
1B   1B        D8            54    Keypad /
