Author Topic: Desktop dual monitor stand  (Read 4402 times)
Offline keyboardlover
« on: Sun, 13 March 2011, 11:16:26 »
Looking to get something like this:
http://www.amazon.com/Planar-997-5253-00-Monitor-Stand-Black/dp/B0013TZRUA
Is that one any good? What do you recommend?
I have 2 Dell U2211H's.
« Last Edit: Sun, 13 March 2011, 11:21:36 by keyboardlover »
Offline nanu
    • http://T-T.be/portal
« Reply #1 on: Sun, 13 March 2011, 12:04:33 »
If I were in your shoes I'd probably get the cheapest thing which could be this, at monoprice.
Offline vun
  • Just one more thing
« Reply #2 on: Sun, 13 March 2011, 12:29:54 »
Quote from: nanu;311007
I'd prefer going in the opposite direction, though I might not remember correctly.
If I do remember correctly, those are somewhat costly IPS monitors, I'd spend a little more money to make sure the stand won't fail and risk damaging them.
Offline nanu
« Reply #3 on: Sun, 13 March 2011, 12:42:06 »
If the stand is in fact solidly built then you question how solid the desk is. You definitely wouldn't want to mount this thing onto particle board.
« Reply #4 on: Sun, 13 March 2011, 12:44:50 »
My desk is solid wood, thanks =)
Offline Lpb45
« Reply #5 on: Sun, 13 March 2011, 12:53:31 »
how much do the u2211's you have weigh?  If they are within the limit of the mono price posted it should be just fine, mono price makes solid stuff for the most part.
Topre - 86U   |   Filco - Tenkeyless Linear Red
Filco - Tenkeyless Blue       |   Filco - Fullsize Non NKRO Blue (Work)
« Reply #6 on: Sun, 13 March 2011, 12:57:55 »
Approx. 6.45kg (14.22lbs) each.
The thing that I like about the one I posted though is that it has a platform so it looks more sturdy.
« Last Edit: Sun, 13 March 2011, 13:01:12 by keyboardlover »
Offline Lpb45
« Reply #7 on: Sun, 13 March 2011, 13:00:35 »
Quote from: keyboardlover;311040
Max Weight:  15kg (33lbs)
VESA:  75x75mm and 100x100mm
Display Size:  10" to 23"*
you are within range albeit at close to the top of the range with both monitors on it but you should be fine.
Offline kiczek
« Reply #8 on: Tue, 22 March 2011, 20:12:14 »
Quote from: keyboardlover;310992
OMG overpriced go head over to monoprice
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10828&cs_id=1082808&p_id=5560&seq=1&format=2
SOOO much cheaper
