Author Topic: Filco Majestouch NKR Cherry MX Blue Switches  (Read 4404 times)
Offline cYberc0re
  • Trade Count: (0)
« on: Tue, 15 March 2011, 00:59:18 »
I've been searching and searching for a Filco Majestouch with blues and NKR, and numpad, however, its pretty damn difficult.
I'm looking for a reasonably priced Filco, in good to new condition. Preferably with box and accessories.
I live in the US, in Illinois to be precise, and I'm willing to pay shipping as well for the US only.
« Last Edit: Tue, 15 March 2011, 02:03:31 by cYberc0re »
Offline manfaux
  • Trade Count: (0)
« Reply #1 on: Tue, 15 March 2011, 01:53:09 »
May I suggest the Leopolds?
Offline cYberc0re
  • Trade Count: (0)
« Reply #2 on: Tue, 15 March 2011, 01:59:32 »
I'd buy Leopolds, if they were in stock. :(
Offline cYberc0re
  • Trade Count: (0)
« Reply #3 on: Tue, 15 March 2011, 02:09:27 »
16 more days. Plus I'm looking for a numpad too, Leopolds are tenkeyless :(
Offline bicycle_wreck
  • Trade Count: (0)
« Reply #4 on: Tue, 15 March 2011, 09:10:19 »
I'm looking for the same thing. Need the numpad for work. Bump.
Das Keyboard Professional / HHKB Pro 2 / Filco Majestouch Tenkeyless (Cherry Blues)
Offline Lpb45
  • Trade Count: (0)
« Reply #5 on: Tue, 15 March 2011, 11:20:34 »
I have a filco 104 w/ blues but does not have NKR (Silver filco label) I would do $100 shipped to the CONUS.  I have had this since the beginning of February and the space bar is starting to get shiney, this is my work keyboard.
Also I do have the original box and plastic cover from EK including the red esc, this was leftover stock bought from Majestouch on these forums and has the EK 1 year warranty
« Last Edit: Tue, 15 March 2011, 11:33:03 by Lpb45 »
Topre - 86U   |   Filco - Tenkeyless Linear Red
Filco - Tenkeyless Blue       |   Filco - Fullsize Non NKRO Blue (Work)
  • Trade Count: (0)
« Reply #6 on: Tue, 15 March 2011, 12:57:30 »
Quote from: Lpb45;312123
You have a PM.
Offline Lpb45
  • Trade Count: (0)
« Reply #7 on: Tue, 15 March 2011, 13:50:32 »
Here's some pics I took at work trying not to get caught messing around lol
Offline cYberc0re
  • Trade Count: (0)
« Reply #8 on: Tue, 15 March 2011, 15:16:17 »
Quote from: Lpb45;312213
Appreciate the effort. Glad you didn't get caught! What exactly does it mean when the spacebar is getting shiney? Is that just from use, or oil from skin building up?
Offline Lpb45
  • Trade Count: (0)
« Reply #9 on: Tue, 15 March 2011, 15:26:42 »
its from use and happens to every filco because of the keys they use.  Ripster or someone else can probly go into detail on why it gets shiny so fast for filcos
Offline DanGWanG
  • Trade Count: (0)
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #10 on: Tue, 15 March 2011, 15:33:10 »
The finish on the spacebar is coated with some material, that over time your fingers rub off.  Upon rubbing it off, the natural oil on your fingers probably polish it a bit, kind of like wax for a car...except its permanent.
Offline cYberc0re
  • Trade Count: (0)
« Reply #11 on: Tue, 15 March 2011, 15:42:25 »
This friday I'm trying out a cherry MX blue keyboard, if I like the feel, I'll most likely buy it from you LPB.
Thanks for the quick responses. (Is the spacebar the only key getting slightly shiny?)
EDIT: Right now my keyboard is 95% shiny, so I suppose I wont notice a difference right away.
Offline Lpb45
  • Trade Count: (0)
« Reply #12 on: Tue, 15 March 2011, 15:54:19 »
it seems that some of the keys are a bit shiny but nowhere near the spacebar, you can probly see it better in the picture then I can describe it.  Wish I had a better camera, my htc incredible will have to do for now.
Also thanks for explaining that Ripster and Dang!!
« Last Edit: Tue, 15 March 2011, 16:05:21 by Lpb45 »
Offline DanGWanG
  • Trade Count: (0)
  • Higher Standards
« Reply #13 on: Tue, 15 March 2011, 16:06:18 »
The Filco keys are notorious for getting shiny quick.
You can prolong the shiny effect by replacing your keys with higher quality keycaps (i.e. POM, PBT).  There's a groupbuy going on right now for 104-set PBT keycaps.
Offline Lpb45
  • Trade Count: (0)
« Reply #14 on: Tue, 15 March 2011, 18:37:46 »
give us the munnnnneeeeee lebowsski
