Author Topic: PBT 104 keycaps  (Read 202582 times)
Offline MrSneis
PBT 104 keycaps
« Reply #350 on: Fri, 06 May 2011, 14:24:55 »
Really nice looking there tubby.
I now have both sets of PBT keys on my Filco and Leo; PITA to get the glue off.  I clumped the glue up into a big ball and used that to unstick the bottoms, one key at a time.  Not too hard or messy, just a little time consuming.
Sadly the Leo's space bar must remain stock.
Knock on wood I don't see any issues with the way the keycaps attach and remove to the cherry stems on these boards.
Filco Tenkeyless Brown | Filco Tenkeyless-2 Blue | Leopold Tenkeyless Blue
Offline nocturn4l3030
PBT 104 keycaps
« Reply #351 on: Fri, 06 May 2011, 18:50:17 »
if you don't have any of that stuff they're recommending to remove the glue.. i used packaging tape to remove it.. it took quite a long ass time to do...
i do love the keycaps though
« Last Edit: Fri, 06 May 2011, 18:58:12 by nocturn4l3030 »
What happens when you discover GeekHack:
[strike]Black Ducky dk1087 Cherry (Brown)
Topre Realforce 103UB 55g
Cherry G80-8113HRBUS-2 (Clear)
White PLU ML-87 (Blue)
1990 IBM Model M 1391401
Cherry G80-3000LSCEU-0 (Blue)
[/strike]
Cherry G80-3600LYCEU-2 (Red)
Topre Realforce 86UB
Filco Tenkeyless (Brown)
[/SIZE]
Offline godofdeath
PBT 104 keycaps
« Reply #352 on: Fri, 06 May 2011, 19:02:42 »
i find it just easier to pour alcohol on a microfiber cloth and rub it and it gets off
gets on your hand tho sometimes
Offline bionicroach
PBT 104 keycaps
« Reply #353 on: Fri, 06 May 2011, 20:10:13 »
I had the best results removing the glue with a lint / cat hair roller.  Still a PITA, but no solvent smells.  (Although maybe sniffing fumes kills enough brain cells to make the job seem less boring?)
Offline tubby
PBT 104 keycaps
« Reply #354 on: Fri, 06 May 2011, 22:15:30 »
Quote from: MrSneis;342612
Thanks, MrSneis :)
I didn't get the 104 PBT set; wanted a blank white set but wasn't available yet.
My friend who joined my order, however did. And lucky enough he got a glue-less set :)
Did your 104 set come in 3 separate small boxes, or was it neatly arranged like the pic on the first post? Glued version, I would presume would be the latter?
Realforce 87UB SE1700 | HHKB Pro 2 | Filco Kobo Red Wood | Filco FKBN87MR/CB2 | Filco FKBN97MRL/EW2 | Filco FKBN87MC/EY2 | Filco FKBN87M/EMU2 | Filco FKBN104M/EB-AI | Filco FKBN104MC/EB | Ducky DK9008 | KBC Poker brown | Realforce 23UB WC01B0 | Filco FKB22MB
Offline godofdeath
PBT 104 keycaps
« Reply #355 on: Fri, 06 May 2011, 23:07:28 »
comes in  one box for a sex, or so mine did, bong is keyboard like length long
Offline godofdeath
PBT 104 keycaps
« Reply #356 on: Fri, 06 May 2011, 23:08:52 »
i dont think 10% off is worth the work to get the stuff off, shoulda been like 50% lol
Offline tubby
PBT 104 keycaps
« Reply #357 on: Sat, 07 May 2011, 01:26:29 »
Quote from: godofdeath;342860
Was that your first time typing on a keyboard with blank caps? Nah jk ;p
So it would seem glued version would be the keyboard-length box, while the glue-less ones are split into three small boxes.
The keyboard-length one seems pretty nice to have for placing the unused caps.
Offline MrSneis
PBT 104 keycaps
« Reply #358 on: Sat, 07 May 2011, 01:46:13 »
My two sets of keys came in two separate thin boxes that were longer than the standard Filco or Leopold box.
Offline n19htmare
PBT 104 keycaps
« Reply #359 on: Sat, 07 May 2011, 02:23:31 »
The white on black keyboard base like the filco would look nice.
Offline nhwhaup
PBT 104 keycaps
« Reply #360 on: Sat, 07 May 2011, 04:17:33 »
Quote from: n19htmare;342902
 That's my plan to put the white keycaps on my black Filco. I can't wait - my keycaps are on their way and hopefully I should get them by the end of the week. I'll share a photo of my two toned black and white board along with my two toned mouse.
Current in order of preference:  RealForce 87U Silent White with variable weighted keys X 2, Filco Majestouch 2 Tenkeyless with Linear Reds, Filco Number-pad, Poker with Linear Reds
Sold or returned:  Multiple Microsoft and Logitech keyboards, Das Keyboard Silent, Cherry 6140, RealForce 103UB, RealForce 86U, Filco Majestouch 2 full sized with Linear Reds
Offline fartbutt
PBT 104 keycaps
« Reply #361 on: Sat, 07 May 2011, 12:37:16 »
I got my black engraved the other day, that adhesive was annoying, thankfully I wasn't using the letter keys. The original leopold space bar matches the black of the new buttons, which is good since you can't switch out that due to the different supports. I'll post a pic later.
Offline fartbutt
PBT 104 keycaps
« Reply #362 on: Sat, 07 May 2011, 13:50:45 »
Quote from: fartbutt;343017
two terrible pictures, maybe they will even each other out =/
Offline grilkip
PBT 104 keycaps
« Reply #363 on: Sat, 07 May 2011, 14:03:47 »
Those white keys on the blue filco look sexy as hell.
Filco tenkeyless (browns) - IBM Model M - Cherry G80-3000LSCEU (blues) Das Prof. S (blues)
ANSI FTW
Offline godofdeath
PBT 104 keycaps
« Reply #364 on: Sun, 08 May 2011, 17:23:46 »
purple keys
Offline Chobopants
PBT 104 keycaps
« Reply #365 on: Mon, 09 May 2011, 09:55:47 »
Are these still purchasable? The second post says stops April 1st. Just curious. The grey on white is gorgeous.
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
Offline nhwhaup
PBT 104 keycaps
« Reply #366 on: Mon, 09 May 2011, 17:38:29 »
Quote from: Chobopants;343793
Now wouldn't your Filco with the reds look great with the gray on white keycaps?  I should have mine by the end of this week and will post showing them on the Filco.  I think from the posts Imsto still had some stock of these gray on white.
Nhwhazup
Offline jinzo.pk3
PBT 104 keycaps
« Reply #367 on: Wed, 11 May 2011, 08:01:58 »
imsto, what kind of stock do you have left?
payment sent for a set of black engraved anyway.
Offline Chobopants
PBT 104 keycaps
« Reply #368 on: Wed, 11 May 2011, 17:07:58 »
Quote from: nhwhaup;344043
Nhwhazup
Exactly what I'm thinking! Will send a payment and see what happens then hehe.
Offline godofdeath
PBT 104 keycaps
« Reply #369 on: Wed, 11 May 2011, 17:32:22 »
is there anyway to get white on black?
Offline godofdeath
PBT 104 keycaps
« Reply #370 on: Wed, 11 May 2011, 19:57:11 »
Thought that was gold on black?
Offline dreamingftw
PBT 104 keycaps
« Reply #371 on: Thu, 12 May 2011, 13:25:47 »
anymore white on white?
Offline Tempy
PBT 104 keycaps
« Reply #372 on: Thu, 12 May 2011, 16:16:33 »
anymore black engraved?
Proud owner of a Filco TKL with Blues, Noppoo Choc Pro with Blues, Leopold 104 with Browns and a CoolerMaster QF with reds
Sc2 stats
Offline gamingarena
PBT 104 keycaps
« Reply #373 on: Thu, 12 May 2011, 20:02:36 »
Me too i'm interested in black engraved, let me know if there is some left.
Thanks
Leopold Tenkeyless Brown, DAS S Professional Blue, Realforce 103UB Topre
Offline godofdeath
PBT 104 keycaps
« Reply #374 on: Thu, 12 May 2011, 22:47:16 »
are there any grey on white left?
Offline SmokinWaffle
PBT 104 keycaps
« Reply #375 on: Fri, 13 May 2011, 08:38:12 »
Is there any possibility of getting the EU Layout?
Me no likey tiny enter key.
Offline daerid
    • Rossipedia
PBT 104 keycaps
« Reply #376 on: Fri, 13 May 2011, 10:36:05 »
Quote from: Tempy;345495
Ditto. Also, what about black blank (Otaku) keycaps? Are those available? I need a replacement set for my Das Keyboard (after six months it's almost completely shiny)
Offline xbb
PBT 104 keycaps
« Reply #377 on: Fri, 13 May 2011, 10:50:25 »
Quote from: godofdeath;345160
I posted a pic with gold on black keycaps here (you can see pretty much the real color):
http://geekhack.org/showthread.php?16260-PBT-104-keycaps&p=332995&viewfull=1#post332995
Offline Index
PBT 104 keycaps
« Reply #378 on: Fri, 13 May 2011, 11:26:16 »
itsmo, if you have anymore black blank keycaps, I would like to request a set.
Gaming Keyboard: Leopold FC200RT/ABN
Work Keyboard: HHKB Pro 2 PD-KB400B
Offline imsto
    • imsto.cn
PBT 104 keycaps
« Reply #379 on: Fri, 13 May 2011, 22:59:56 »
black engraved
black on white
purple on black
available.
imsto.cn
imsto's AiKB Taobao Shop
IBM Model M*3, IBM M13,M5, IBM with balls.Cherry   3000  3494 3700 4100*6 700*2 11900 8113 DAS4 TG3 KBC PokerDucky09Ducky1087 apple pink alps Ducky bull,tiger,rabbit,dragon version No:0000002
Offline Tempy
PBT 104 keycaps
« Reply #380 on: Sat, 14 May 2011, 01:27:45 »
Quote from: imsto;345981
black engraved
black on white
purple on black
available.
Payment sent for black engraved set,
Sc2 stats
Offline dreamingftw
PBT 104 keycaps
« Reply #381 on: Sat, 14 May 2011, 01:41:42 »
will you be getting white on white anytime soon?
Offline spdx
PBT 104 keycaps
« Reply #382 on: Sat, 14 May 2011, 01:56:56 »
Received a black engraved today. Looks good. Thanks
Offline nhwhaup
Gray on White - Filco
« Reply #383 on: Sat, 14 May 2011, 07:33:27 »
Seemed like I waited forever but they finally arrived.  Loving my new keyboard. Filco with Cherry reds, sound dampening pads and new gray on white key caps.
[ Attachment Invalid Or Does Not Exist ] 18118[/ATTACH]
Offline dreamingftw
PBT 104 keycaps
« Reply #384 on: Sat, 14 May 2011, 17:46:12 »
This is my first MO. Are the prices USD? And what's eta for shipping to US? I am interested in the pbt 104 white engraved or grey on white. Do you have any available? Thanks.
Offline godofdeath
PBT 104 keycaps
« Reply #385 on: Sat, 14 May 2011, 17:48:38 »
Quote from: nhwhaup;346096
(Attachment Link) 18118[/ATTACH]
did you remove the filco logo or is it black?
Offline nhwhaup
PBT 104 keycaps
« Reply #386 on: Sat, 14 May 2011, 19:31:29 »
[BOOK][/BOOK]
Quote from: godofdeath;346319
The logo is still there but the photo doesn't show it.  The logo is actually a grayish silver which compliments the the gray lettering on the keys.
Offline godofdeath
PBT 104 keycaps
« Reply #387 on: Sat, 14 May 2011, 21:02:44 »
Quote from: nhwhaup;346365
[BOOK][/BOOK]
o so its the non nkro one or majestouch2
Offline Tempy
PBT 104 keycaps
« Reply #388 on: Sat, 14 May 2011, 22:34:17 »
Quote from: godofdeath;346383
i assume its the limited edition reds majestouch, all of the ficos with red switches sport the black filco logo
Sc2 stats
Offline nhwhaup
PBT 104 keycaps
« Reply #389 on: Sun, 15 May 2011, 10:38:00 »
Quote from: Tempy;346411
It is the limited edition with reds currently being sold on Amazon. The Filco logo is a brushed silvery gray.
Offline Tempy
PBT 104 keycaps
« Reply #390 on: Sun, 15 May 2011, 11:24:12 »
Quote from: nhwhaup;346599
i own a filco reds tenkeyless and to me its like a black graphite
Sc2 stats
Offline tubby
PBT 104 keycaps
« Reply #391 on: Mon, 16 May 2011, 00:03:17 »
Quote from: ripster;346602
When someone gets a Gen 2 Filco with switches OTHER than red please confirm whether it's silver or gray.
Someone at vr-zone posted a pic of his brown & blue switch Majestouch 2... and its gray.
My tenkeyless red switch doesn't seem to look as dark though. I would still call it silver... darkish silver?
pictures around the web makes it appear like gun metal black, some even look jet-black.
Another trivial difference: the Majestouch2 is horizontally brushed while the brushing on non NKRO seems arced.
« Last Edit: Tue, 17 May 2011, 01:18:27 by tubby »
Offline Wibox
PBT 104 keycaps
« Reply #392 on: Wed, 18 May 2011, 07:36:50 »
Would love to buy white engraved. Let me know when these are available and I will paypal over money :]
!! YKBDS !! - KBC Poker (Ergo Clear Cherry) - Apple M0116 (Pink ALPS) - Apple M0115 (Orange ALPS) - Das Keyboard (Blue Cherry) - IBM Model F - IBM Model M - Dell AT101W (White ALPS) - Cherry POS 8000 (Clear Cherry) - Apple Extended II (Cream ALPS)
Offline daerid
    • Rossipedia
PBT 104 keycaps
« Reply #393 on: Wed, 18 May 2011, 13:45:26 »
Got a Filco 2 Brown TKL. And yeah, it's gray, like a gunmetal really.
Offline imsto
    • imsto.cn
PBT 104 keycaps
« Reply #394 on: Thu, 19 May 2011, 07:22:08 »
Quote from: Wibox;347928
 yes, available   only 8 left now.
imsto.cn
Offline Chobopants
PBT 104 keycaps
« Reply #395 on: Thu, 19 May 2011, 09:02:47 »
Ordered 2 black on white sets, psyched! Have to figure out what I'm going to do with all the keys since I have 1 full size and 2 tenkeyless haha.
Offline Wibox
PBT 104 keycaps
« Reply #396 on: Thu, 19 May 2011, 10:18:22 »
Quote from: imsto;348435
Awesome. These are the white on white engraved right? I have placed my order :]
Offline litster
  • rare caps?! THAT'S A SMILIN
PBT 104 keycaps
« Reply #397 on: Fri, 20 May 2011, 01:22:51 »
Anyone tried the white caps on a black body?  Any pictures?  Thanks.
EDIT: sorry, I am an idiot.  It is just on the page before.  Thanks.  May have to order a set, or two :-)
« Last Edit: Fri, 20 May 2011, 01:26:04 by litster »
Offline litster
PBT 104 keycaps
« Reply #398 on: Fri, 20 May 2011, 02:07:09 »
Sorry, it's me again.  Do you know if the seller give shipping discount for shipping 2 sets together?  PM'ed him but thought someone might know because I see some of you purchased 2 sets.  Thanks.
Offline jinzo.pk3
PBT 104 keycaps
« Reply #399 on: Fri, 20 May 2011, 02:38:37 »
Quote from: litster;348885
If you have a look at page 2/3 people have been paying $35 postage for 2 sets
