Author Topic: POM Caps?  (Read 4446 times)
Offline digitalleftovers
POM Caps?
« on: Tue, 15 March 2011, 16:18:38 »
Out of curiosity, what is the best (cheapest) way to obtains POM key caps?  They would need to be Cherry MX compatible.
My best guess is that I would need to find an old board to harvest them from.  Can anyone offer suggestions for what boards would be most likely to have POM caps?
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline Kacee
POM Caps?
« Reply #1 on: Tue, 15 March 2011, 16:27:58 »
G80-3000 black casing...
I have one and seriously I don't know if I want POM keycaps, PBT keycaps from Cherry are much better.
Offline panda-R
POM Caps?
« Reply #2 on: Tue, 15 March 2011, 16:28:29 »
Quote from: Kacee;312300
what u don't like about them?
DO YOU FEEL THE BEAT? I DO.
One Keyboard to DOOM them all, REALFORCE.
POM Caps?
« Reply #3 on: Tue, 15 March 2011, 16:35:07 »
Its mostly curiousity.  I wasn't able to find much info about keys specifically, just the material.  Does anyone know of any Grey, beige, or white boards that have them?
Keyboards:
Offline Kacee
POM Caps?
« Reply #4 on: Tue, 15 March 2011, 16:41:04 »
Quote from: panda-R;312301
They have a slippery feeling to my fingers. And I guess POM is very hard to work with as I see imperpections of the surface where the stems are (can't think of the right word)
Offline laden3
POM Caps?
« Reply #5 on: Tue, 15 March 2011, 18:42:45 »
Quote from: digitalleftovers;312305
AFAIK POM comes in black only. "Original" colored ones will be available some time in the future... distant future......
I rrrove brrracks.
POM Caps?
« Reply #6 on: Tue, 15 March 2011, 18:49:50 »
I think some of these are POM
Yes, I found it in webwit's image directory.  If I am wrong, please correct me.
Keyboards:
Offline RiGS
POM Caps?
« Reply #7 on: Tue, 15 March 2011, 19:16:44 »
Pom keys are very reflective.
Offline laden3
POM Caps?
« Reply #8 on: Tue, 15 March 2011, 20:00:53 »
Quote from: digitalleftovers;312366
Yes, you are WRONG+right. Delrin isn't Delvin. Don't make "the Moogle's mistake" and google is your best friend.
Delrin keycaps can still be made in different colors, but AFAIK no keycaps manufacturers make them. Why? Demands.
I rrrove brrracks.
Offline Kacee
POM Caps?
« Reply #9 on: Tue, 15 March 2011, 22:54:43 »
It's the lower rightmost one.
POM Caps?
« Reply #10 on: Wed, 16 March 2011, 01:20:01 »
Quote from: laden3;312395
Ahh... Now I understand. And now that I know more about Devlin, I'm somewhat intrigued.  They might actually fit on a 1087, which has wider key wells than a filco.
Back to POM.  It sounds like my best black cherry G80's?  Any date range I should look for?
Keyboards:
Offline sixty
    • http://deskthority.net
POM Caps?
« Reply #11 on: Wed, 16 March 2011, 01:28:11 »
Modern ones, or any lasered ones actually. All their black lasered keys are POM. The old ones are double shot ABS.
POM Caps?
« Reply #12 on: Wed, 16 March 2011, 05:58:26 »
I'm not a fan of Cherry's black lasered POM caps. Too slippery.
