Author Topic: Removing HHKB Stabalizer Keys  (Read 3095 times)
Offline puffyjacket45
« on: Mon, 21 March 2011, 17:01:10 »
« Last Edit: Fri, 24 July 2015, 15:03:28 by puffyjacket45 »
Offline theferenc
« Reply #1 on: Mon, 21 March 2011, 17:13:40 »
I've never had any issues pulling keys off mine. I find the easiest way to pull the space bar is to pull the keys on either side, and then use my hands to pull it up from both sides simultaneously.
There are no visible stabilizers, at least of the wire variety. For the space bar, at least, there are 2 stubs underneath, on either side, that slot into those different looks "switches" on either side of the white rubber pieces that provide stability.
Hope that helps, and welcome to geekhack!
« Reply #2 on: Mon, 21 March 2011, 17:57:42 »
« Last Edit: Fri, 24 July 2015, 15:04:00 by puffyjacket45 »
Offline RiGS
« Reply #3 on: Mon, 21 March 2011, 18:35:58 »
So to confirm those little 2 black nubs on either side of the rubber stoppers on the keyboard slide into the 2 fitting holes underneath the spacebar key?
Yep.
