Author Topic: discovered bug form xp to 7!  (Read 2824 times)
Offline typo
« on: Mon, 21 March 2011, 18:11:25 »
set an application to constantly read and write to the hd. set the power saving to turn off the monitor some minutes before the hd turns off. any time you like as long as the monitor turns off before the hdd does. the monitor will go into power saving. then the hd will try to go into power saving while it is being read from or written to. bam! the monitor will wake up! this will continue endlessly.
i wonder if i am the first to notate this bug. if you don't think it works, make sure something is acessing the drive at the time it goes into power saving.
Offline typo
« Reply #1 on: Mon, 21 March 2011, 18:22:18 »
that's typo to you buddy! true to my name.
Offline keyboardlover
« Reply #2 on: Mon, 21 March 2011, 18:28:08 »
Quote from: ripster;315494
I discovered a bug in your post title.
Offline nanu
    • http://T-T.be/portal
« Reply #3 on: Mon, 21 March 2011, 18:46:00 »
I bet your application reloads geekhack every five minutes...
Offline Enzyme
    • http://www.kdclan.net
« Reply #4 on: Tue, 29 March 2011, 08:56:35 »
yeah i get that bug too, often wake up to find my pc looking lonley and passwordless.
you need to disable one of the system messaging settings, i forget which one tho., i did it on my gaming rig a while back.
