Author Topic: NKRO with USB?  (Read 10280 times)
Offline mrsone
  • Recovering Rubber Dome User
NKRO with USB?
« on: Thu, 24 March 2011, 03:23:45 »
I just got a shiny new Noppoo Choc Mini. I was fooling around with it in Notepad for some reason when I noticed that more of my inputs than usual were registering. Then I did the NKRO test here and here and found that the Noppoo Choc has full NKRO even on a USB connection. I didn't think this was possible.
I heard that the Thermaltake Meka G1 keyboard had this feature, too. So does anyone else know any keyboards that support NKRO on a USB connection?
Keyboards currently in my possession:
Filco Majestouch Cherry MX Brown 104 key, Unicomp Spacesaver 104, Rosewill RK-9000RE (Cherry MX Red), Leopold 660C Mini Capacitive keyboard, HHKB Type S, Logitech Illuminated Keyboard
Keypads:
Leopold 210TP Mechanical Keypad (Cherry MX Red), Leopold FC210TP/NB Mechanical Keypad (Cherry MX Brown)
Other Keyboards I have tried:
Filco Majestouch Cherry MX Red, Leopold  FC500RR/AB Linear Touch Cherry MX Red, Razer Blackwidow Ultimate, Razer Blackwidow Ultimate Stealth Edition, Realforce 103U/UB, Realforce 103U Black All 55g, Noppoo Choc Mini 84 Mechanical Cherry MX Black keyboard, Noppoo Choc Mini 84 Mechanical Cherry MX Red keyboard (white and black color versions), PLU G3000 NKRO keyboard (white w/ Cherry MX Red switches), Dell 101AT (black Alps switches), Mattias Mini Quiet Pro (modified white Alps switches), KBT Pure Pro, (2)Happy Hacking Keyboard Professional 2, Leopold FC210TP/CB Tactile Click Cherry MX Blue Tenkey pad
Offline Orphagn
NKRO with USB?
« Reply #1 on: Thu, 24 March 2011, 03:39:10 »
As far as I know, the Noppoo is the only tenkeyless with NKRO over USB.
That's one of the main reasons I really like it.
Keyboards:
KBC Poker
Cherry G80-11900
Cherry G80-3494
Offline bytemeavaj
NKRO with USB?
« Reply #2 on: Thu, 24 March 2011, 04:23:02 »
Quote from: Orphagn;317499
The Filco tenkeyless does as well. I think the Leopolds may as well (not sure).
I\'m a tool.
Offline Orphagn
NKRO with USB?
« Reply #3 on: Thu, 24 March 2011, 04:28:17 »
Didn't know that Filco tenkeyless were NKRO, I always ran mine using PS2. Then again I never tested for NKRO when I had a Filco.
Keyboards:
KBC Poker
Cherry G80-11900
Cherry G80-3494
Offline javifast
NKRO with USB?
« Reply #4 on: Thu, 24 March 2011, 04:50:31 »
I think Filcos are NKRO only with ps2.
Too many keyboards....
Offline Heimdallr
NKRO with USB?
« Reply #5 on: Thu, 24 March 2011, 05:13:23 »
i think with USB you only get 6KRO.
stefano
Offline ch_123
NKRO with USB?
« Reply #6 on: Thu, 24 March 2011, 05:17:24 »
The Noppoo is full NKRO over USB, but it's done in a hackish way (AFAIK, the controller emulates three keyboards). One consequence of this is that it doesn't work with OS X.
Offline Mr. Perfect
NKRO with USB?
« Reply #7 on: Thu, 24 March 2011, 09:10:30 »
The Ducky year of the tiger special edition board is also NKRO using USB. The Microsoft x4 can hit 12KRO using USB, which is perfectly fine for ten fingered people.
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline Ekaros
NKRO with USB?
« Reply #8 on: Thu, 24 March 2011, 09:21:00 »
Quote from: ch_123;317529
Hmm so is it NKRO or 18KRO? ;D Quite intresting way ;D
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline Ekaros
NKRO with USB?
« Reply #9 on: Thu, 24 March 2011, 09:25:37 »
Quote from: ripster;317621
The Ducky G2 and Noppoo are made by the same OEM. Same failure mode in OSX.  Most likely the same controller and firmware.
I'd go for 6KRO with rock solid compatibility over NKRO any day.
I agree, 6KRO over some limited support hack...
[SIGPIC][/SIGPIC]
Offline keyboardlover
NKRO with USB?
« Reply #10 on: Thu, 24 March 2011, 09:25:46 »
Or use PS/2. That's what I do. :D
NKRO with USB?
« Reply #11 on: Thu, 24 March 2011, 09:27:51 »
I use PS/2 on my G80-3494 (KL Kustom 1) via my Thinkpad docking station.
Offline Laggy-gaga
NKRO with USB?
« Reply #12 on: Thu, 24 March 2011, 09:42:34 »
actually it is fake NKRO with USB
there is a conflict with "shift" (only in veryyyyyyyy fast typing speed)
Be honestly I don't quite understand the theory of that guys,
but the manufacturer had  admitted this problem.
Working: Ducky Dragon Blue
Looking for: 356L
For sale:Benchmark DAC1+Stello U3+Amber,RS1i,GS1000i,HE400,HD650,w4r,se535LE
AU only
Offline RiGS
NKRO with USB?
« Reply #13 on: Thu, 24 March 2011, 14:18:21 »
Does this hack introduce any additional lag?
Offline mrsone
NKRO with USB?
« Reply #14 on: Thu, 24 March 2011, 15:57:53 »
Quote from: Ekaros;317620
When I did my "testing" I got 22 keys to register at once. I do not have a good testing apparatus to test all the keys at once, other than just dropping a book on the board.
Keypads:
Offline JBert
NKRO with USB?
« Reply #15 on: Thu, 24 March 2011, 17:19:18 »
18KRO would be "practically NKRO" in my book...
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline bpiphany
NKRO with USB?
« Reply #16 on: Thu, 24 March 2011, 17:55:03 »
Are USB protocols predetermined once and for all or is it possible to write your own? In that case it shouldn't be too hard to just have a keyboard that acts as a regular keyboard in BIOS and then becomes some extended sort of keyboard when drivers are loaded.
Offline Ekaros
NKRO with USB?
« Reply #17 on: Thu, 24 March 2011, 18:20:36 »
Quote from: JBert;317952
N must equal the amount of keys on board ;D Otherwise it's N>nKRO
[SIGPIC][/SIGPIC]
Offline panda-R
NKRO with USB?
« Reply #18 on: Thu, 24 March 2011, 18:30:04 »
Quote from: javifast;317517
the new filcos are NKRO over USB! HOT DOG!
DO YOU FEEL THE BEAT? I DO.
One Keyboard to DOOM them all, REALFORCE.
Offline bytemeavaj
NKRO with USB?
« Reply #19 on: Thu, 24 March 2011, 18:34:32 »
Quote from: Heimdallr;317526
What are you guys talking about? Filco is NKRO through USB.
I\'m a tool.
Offline bytemeavaj
NKRO with USB?
« Reply #20 on: Thu, 24 March 2011, 18:37:34 »
My bad, I used the notepad example and "thought" my Filco was NKRO through USB.
I\'m a tool.
Offline killy
NKRO with USB?
« Reply #21 on: Thu, 24 March 2011, 21:28:29 »
I just held both shift keys down and typed out 'the quick brown fox jumps over the lazy dog.' No problem.
Offline JBert
NKRO with USB?
« Reply #22 on: Sun, 27 March 2011, 15:19:53 »
Quote from: PrinsValium;317981
Actually, if the BIOS has properly implemented USB HID it would ask the keyboard to switch to "legacy mode" while the normal mode could use a NKRO protocol.
Sadly, BIOSes and OS drivers may not implement USB HID properly, hence why keyboard manufacturers choose the safe route by using the legacy protocol all around.
The storage list:
[/SIZE]
Offline bpiphany
NKRO with USB?
« Reply #23 on: Mon, 28 March 2011, 14:50:19 »
Quote from: JBert;319685
A simple case of everyone following their own standard then, no big surprise I guess.
