Author Topic: Request Info about 3 keyboards  (Read 7728 times)
Offline datacenter
« on: Fri, 25 March 2011, 03:45:16 »
Hi guys :biggrin:
Is these keyboards mechanical:
1. CHICONY Model Number KB-5916
2.K-452 C N 8822
S/N 0027910
Made in Taiwan R.O.C.
http://picbg.net/u/53086/44313/535950.jpg
3. CHERRY - Made in USA model LR 108674
4. Do you know any Alcatel keyboards... and if there are mechanical ones?
Thanks in advance!
« Reply #1 on: Fri, 25 March 2011, 04:27:59 »
Quote from: datacenter;318247
There are a few that use Acer switches.
Alcatel (Acer 6313-KW)
Alcatel branded MFII board
The Acer switches have ALPS-compatible key stems, are clicky. They feel somewhat like White ALPS, but perhaps with more friction, especially if you press a key off-center. People have also reported that they would be somewhat inconsistent in feel. On some boards they activate before the click -- on others after the click, and sometimes depending on how hard you type.
Offline datacenter
« Reply #2 on: Fri, 25 March 2011, 04:37:34 »
Quote from: Findecanor;318260
THANKS!
Update:
1. CHICONY Model Number KB-5916 - just got it, took it apart.... cheap rubber dome :(
Offline TeacherGeek
Re: Request Info about 3 keyboards
« Reply #3 on: Tue, 19 November 2019, 12:50:39 »
bump
« Reply #4 on: Tue, 19 November 2019, 12:52:42 »
:confused:
Sent from my SM-G970U1 using Tapatalk
