Author Topic: What makes a Topre more quiet?  (Read 3037 times)
Offline digitalleftovers
« on: Fri, 25 March 2011, 13:43:25 »
What does "silent" or "low noise" mean in terms of a topre mechanism? (91Ubk-S) Is it a lighter switch? Dampened?  I'm not sure, and I didn't see where it was discussed in the wiki. Thanks!
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline RiGS
« Reply #1 on: Fri, 25 March 2011, 13:47:39 »
I think the foam ring dampens the rebound of the switch, but as a result of this mod the switch actuates earlier.
« Reply #2 on: Fri, 25 March 2011, 13:53:14 »
Quote from: RiGS;318476
The foam rings are factory installed?
Keyboards:
Offline RiGS
« Reply #3 on: Fri, 25 March 2011, 13:55:52 »
Yep, the foam rings are factory installed on the silent models.
« Reply #4 on: Fri, 25 March 2011, 13:56:46 »
Does anyone have a picture of them?
Keyboards:
Offline RiGS
« Reply #5 on: Fri, 25 March 2011, 14:02:43 »
ScarFace made a good review on that.
Offline RiGS
« Reply #6 on: Fri, 25 March 2011, 14:05:41 »
There is a whole topic on the low-noise Realforce.
« Reply #7 on: Fri, 25 March 2011, 15:04:07 »
Quote from: RiGS;318492
That is exactly what I was looking for.  Thank you.
Keyboards:
Offline HaveANiceDay
« Reply #8 on: Fri, 25 March 2011, 16:05:27 »
Next time, for the ultra silent, they should remove the spring.
Filco Tenkeyless Brown with beige cherry doubleshots (home)
Realforce 86U (work)
Get you own Phantom NAO!
