Author Topic: Looking For: Large Print Keyboards / Keycaps  (Read 6492 times)
Offline REVENGE
« on: Mon, 28 March 2011, 22:09:11 »
Any recommendations for a large print mechanical keyboard with Cherry Blues or Cherry compatible large print key caps? The only board I've located so far is the Scorpius 35 Pro, but the yellow font color is a turnoff. The pad printing is also a concern, but I've never heard of lasered or doubleshot large print key caps.
Offline strum4h
« Reply #1 on: Mon, 28 March 2011, 22:22:56 »
The doubleshot group buys from signature plastics have pretty large print from what I have seen.
[SIGPIC][/SIGPIC]
Filco Tenkeyless with Browns  - SIIG minitouch GHSS
Offline REVENGE
« Reply #2 on: Mon, 28 March 2011, 22:34:34 »
Ah, I think that's just what I need, thanks! That stock font + a Scorpius M10 would do.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #3 on: Mon, 28 March 2011, 23:16:43 »
The doubleshots have big fonts for the letters only.  The other keys are traditional size fonts, perhaps even lacier than most.
Also, the set is designed for Filco and similar boards, with accomodations for G80-3000 and a few similar boards.  You may have fit issues with the bottom row keys on the M10.  I also don't know about the fit for stabilized keys.
Overton130, Box Pale Blues.
Offline Hak Foo
« Reply #4 on: Tue, 29 March 2011, 00:21:47 »
Not the profile-- which is not much of an issue if you're swapping all keys-- the size.  I think the M10's windows key is single-width, and most likely the other bottom row keys are a different shape
Offline Brodie337
« Reply #5 on: Tue, 29 March 2011, 01:08:17 »
Apparently there's a DSI keyboard with HUGE letters, and I think Yellow ALPS switches (Linear?). I've never seen it for sale though, but I imagine it'd be cheaper than buying a keyboard plus separate caps, though you lose out on switch choice.
Offline REVENGE
« Reply #6 on: Tue, 29 March 2011, 01:18:43 »
Quote from: Hak Foo;320451
I was thinking of only swapping the alphanumeric keys, would that be an issue mix and matching with stock modifier keys?
Quote from: Brodie337;320466
I know, the board has to have Cherry Blues.
Offline Hak Foo
« Reply #7 on: Tue, 29 March 2011, 01:28:25 »
Probably not much of an issue.  IBut the number keys are standard size.
Offline Ascaii
« Reply #8 on: Tue, 29 March 2011, 14:37:34 »
As far as I know there is a Cherry g81-3000 with extra large letters, single keys would be g80 compatible.
Offline nolo
« Reply #9 on: Tue, 29 March 2011, 15:04:35 »
Hi, maybe these boards are interesting for you: VIG-G84-4100WB, VIG-G80-3000WB .
Offline BucklingSpring
« Reply #10 on: Tue, 29 March 2011, 16:15:12 »
Would you consider backlit as an alternative to large fonts? Certainly helps for high visibility?
If yes Deck or XArmor U9BL/S
Boards I own, click ->
Offline Reaif
« Reply #11 on: Tue, 29 March 2011, 16:17:43 »
I might recommend a Cherry G84-4100. Some of them have pretty big font, but it appears that the black ones are pretty standard. See this one.
They don't have blues though. They have the ML switch which is a lower profile mechanical switch with a linear force curve.
Currently own:
Das S Ultimate with Browns
Cherry G84-4100 with ML Linear switches
Memorex Telex with NMB Space Invaders
Leopold with Blues
