Author Topic: Keyboard Cleaning  (Read 1470 times)
Offline zerosxl
Keyboard Cleaning
« on: Mon, 28 March 2011, 23:08:25 »
How often do I need to clean this filco red. And how do I clean it haha.
Offline Lpb45
Keyboard Cleaning
« Reply #1 on: Mon, 28 March 2011, 23:09:12 »
mail it to me I will clean it for you!
EDIT : Honestly though check the wiki, pretty sure Ripster has a section on cleaning and lubing.
Topre - 86U   |   Filco - Tenkeyless Linear Red
Filco - Tenkeyless Blue       |   Filco - Fullsize Non NKRO Blue (Work)
Offline Brodie337
Keyboard Cleaning
« Reply #2 on: Tue, 29 March 2011, 01:10:24 »
I just pull the caps off, and rinse them in soapy water then set outside to dry. I usually hit the keyboard itself with a vacuum cleaner with a brush head to get the dust and crap out of it.
Offline zerosxl
Keyboard Cleaning
« Reply #3 on: Tue, 29 March 2011, 01:13:50 »
#2
« Last Edit: Tue, 29 March 2011, 01:15:57 by zerosxl »
