Author Topic: WTF Filco ....  (Read 1576 times)
Offline DrunkenDonut
WTF Filco ....
« on: Tue, 29 March 2011, 17:14:34 »
[strike]The '6' just died on my tenkeyless, MX Black :(
I pasted that 6 from a text document I rummaged around for.. LOL
This is after I cleaned the keyboard earlier today but only noticed this a few minutes ago. I only popped off most of the alpha keys and gave it a light brushing - didn't even touch the numbers, so I don't think that had anything to do with it.
Unplugged, re-plugged and still doesn't work. 6 works on another keyboard so it doesn't seem to be a weird software glitch. :(
[/strike]
Nevermind.. I just hit it hard and it works again. -_-;
And yes, I'm still posting this because I already typed it out and don't want it going to waste. :D  What a weird thing for it to do though. Repeated presses (even hard presses) didn't seem to help, but one good wack and it works. Gotta show it who's boss, I guess.
*Hang on to your wallet!*
BTC E5X5R5BTC-5339R-0 (\'90), MS Natural Keyboard Pro (\'99), Sun Type 5c, 2x 1391401, DASK3ULT (\'08), ABS M1, Dell AT101W, M4-1
FKBN87M/EB (\'09), FKBN87ML/EB (\'09), FKBN87Z/EB (\'09), FKBN87MC/NPEC (\'09), G80-3000LQCDE-2 (\'11)
Offline Ekaros
WTF Filco ....
« Reply #1 on: Tue, 29 March 2011, 17:18:27 »
Hmm, yep, when everything else fails, use more force ;D
Likely something was stuck or something...
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline godofdeath
WTF Filco ....
« Reply #2 on: Tue, 29 March 2011, 17:19:44 »
Quote from: DrunkenDonut;320951
[/strike]
are you Gibbs from NCIS?
Offline wanabe
WTF Filco ....
« Reply #3 on: Tue, 29 March 2011, 17:30:37 »
you might have a cold solder joint on the '6' switch
Offline Orphagn
WTF Filco ....
« Reply #4 on: Tue, 29 March 2011, 18:38:29 »
Quote from: godofdeath;320955
LOL! Too bad McGee wasn't here, he could've fixed it.
Keyboards:
KBC Poker
Cherry G80-11900
Cherry G80-3494
Offline kektr0city
WTF Filco ....
« Reply #5 on: Tue, 29 March 2011, 21:44:52 »
Quote from: kalrykh;321124
you ever listen to what mcgee says when he's doing tech ****? it's like star trek when they just start making **** up.
the weird part is there basically 100% spot on when it comes to the forensics / autopsy **** but the tech **** is always suspect.  but then again that's true for almost any show.
WTF Filco ....
« Reply #6 on: Wed, 30 March 2011, 00:43:11 »
Curious, how "sealed" are the key switch mechanisms? Is it easy for particles to get in, or is it pretty much closed off to the outside? If it acts up again I'll likely just reflow the solder joints.
