Author Topic: Motorola Nyxboard Hybrid HTPC remote with keyboard  (Read 5738 times)
Offline Desiato
« on: Tue, 05 April 2011, 11:12:38 »
This looks really interesting, and not just for XBMC.
The thick XBMC remote from Pulse-Eight and Motorola, dubbed the Nyxboard Hybrid, works out of the box with the popular media center platform. In fact, it’s the first remote specifically designed for XBMC.
The Nyxboard Hybrid supports IR to function as a universal remote for your TV and includes an RF adapter for operating your home theater device without line-of-sight. The front of the remote features the usual volume and channel rockers, playback controls and a directional pad while the back is occupied by a QWERTY keyboard.
The feature with the coolest potential is a gyroscope, which tells the remote which side is facing upright.  That means you can hammer away at the miniature keyboard without triggering an unintended volume change from the buttons on the other side.
http://www.tested.com/news/motorola-made-xbmc-remote-now-available-for-presale/2118/
http://www.pulse-eight.com/store/products/96-motorola-nyxboard-hybrid.aspx
Offline digitalleftovers
« Reply #1 on: Tue, 05 April 2011, 11:25:58 »
Big Ass enter on a remote?
LOL...
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline Desiato
« Reply #2 on: Tue, 05 April 2011, 11:45:09 »
Quote from: digitalleftovers;325025
LOL...
I noticed that too.  I think it makes sense in this case because of how the keyboard is held and the size of the keys.
Offline Desiato
« Reply #3 on: Tue, 05 April 2011, 12:23:18 »
Quote from: ripster;325044
Well....
I guess mine COULD be called BigAss.
Mine is more thumb type friendly than a chocolate bar.
Lol - just realized I have a domed Windows key on mine.
It's so thick, it has to be by design.
Judging its size relative to the usb rf adapter, it's about as thick as 1.5 dvd cases.  Testing its height with dvd cases, I can imagine it being very comfortable to operate.
I hope it's balanced and lightweight.
« Last Edit: Wed, 06 April 2011, 03:31:34 by Desiato »
Offline Lpb45
« Reply #4 on: Tue, 05 April 2011, 18:32:44 »
Well....
What remote is this?
Topre - 86U   |   Filco - Tenkeyless Linear Red
Filco - Tenkeyless Blue       |   Filco - Fullsize Non NKRO Blue (Work)
Offline Malard
« Reply #5 on: Tue, 05 April 2011, 18:33:20 »
Quote from: Desiato;325059
Judging its size relative to the usb rf adapter, it's about as thick as on 1.5 dvd cases.  Testing its height with dvd cases, I can imagine it being very comfortable to operate.
Hi,
It's balanced, its a touch under 180grams, depending on the batteries you use.
Dimensions: 197x59x26mm
Cheers
www.pulse-eight.com
