Author Topic: Best solution for no media keys?  (Read 4434 times)
Offline JohnehJH
« on: Tue, 05 April 2011, 16:13:53 »
So I just got my new Filco tenkeyless, and I love it. Thanks everyone for the advice and such. Only had two qualms with it:
  • USB cord is a little short.
  • I forgot I use my media keys quite often.
The only thing I really used was the volume up, down, and mute. Out of curiosity how have you folks dealt with the media keylessness of mechanical boards?
Offline alaricljs
  • I be WOT'ing all day...
« Reply #1 on: Tue, 05 April 2011, 16:17:46 »
Autohotkey is a good choice... Win-plus and Win-minus for vol, Win-0 for mute.. or anything you can think of.
Filco w/ Imsto thick PBT
Offline NimbleRabit
« Reply #2 on: Tue, 05 April 2011, 16:30:43 »
Quote from: alaricljs;325223
I'll second this.  You can choose exactly what keys you want to use and get all of your functionality back.  I personally like this script for volume control, I appreciate having a simple little display:
http://www.autohotkey.com/forum/topic49219.html
Offline Fwiffo
« Reply #3 on: Tue, 05 April 2011, 16:31:13 »
Alternatively, you can use an operating system that actually lets you configure keyboard shortcuts for things. But I use Autohotkey when I'm in Windows.
You can call me... Keyboard Otaku... or not quite...
Offline Culinia
« Reply #4 on: Tue, 05 April 2011, 16:37:26 »
I personally use the application button for volume down and right-ctrl for volume up. Mute = hold application key down.
Offline JohnehJH
« Reply #5 on: Tue, 05 April 2011, 17:50:59 »
Thanks for the help. I set mine to Insert, Home, and Page up as mute, vol down, and vol up respectively. Only because I don't use those keys and I didn't want to have to hit ctrl, shift, or win key.
Offline DrunkenDonut
« Reply #6 on: Tue, 05 April 2011, 19:11:09 »
For those of you in OS X and want to add hot keys (more than the built-in functionality gives you), give Spark a try. (http://www.shadowlab.org/Software/spark.php). It'll do the usual system volume, iTunes control, etc. It can also run scripts, open apps, activate menu items too.
Spark and Autohotkey are definitely must-haves.
*Hang on to your wallet!*
BTC E5X5R5BTC-5339R-0 (\'90), MS Natural Keyboard Pro (\'99), Sun Type 5c, 2x 1391401, DASK3ULT (\'08), ABS M1, Dell AT101W, M4-1
FKBN87M/EB (\'09), FKBN87ML/EB (\'09), FKBN87Z/EB (\'09), FKBN87MC/NPEC (\'09), G80-3000LQCDE-2 (\'11)
Offline clack
« Reply #7 on: Wed, 06 April 2011, 00:09:52 »
i use winamp and i just bind rctrl + arrow key for various playback functions. rctrl + left arrow for prev track, down for play/pause, right for next track, up for playlist
Offline theferenc
« Reply #8 on: Wed, 06 April 2011, 01:06:27 »
Autohotkey should do it in windows, and kde at least has an equivalent tool built in (for this level of stuff, anyway). And I think there is a linux version of autohotkey, but I forget what the developer called it.
Or you can use xmodmap, depending on how your linux system was set up -- X has support for volume control, but your mixer has to support it. Isn't sound in linux fun?
Offline The Solutor
« Reply #9 on: Wed, 06 April 2011, 05:04:40 »
Caming from the Sidewinder X6 (i bought it also because the handy volume rocker) I was very worried about the lack of a nice volume control on my keyboard.
I searched a bit and the only straightforward solution is the expensive (and, seem, not well supported in windows) Powermate.
So I've decided to buy a cheap keyboard provided with this control and dismantle it keeping just the knob.
But then I found Volmouse, is very handy and widely configurable to meet every needs, and using the scroll wheel as volume knob is better than any key combinations.
I also use a sw to have an on screen volume display, there are a lot of them starting from the sidewinder SW to 3rvx to "sound volume hotkeys"
