Author Topic: Clear Switch POKER kit  (Read 3203 times)
Offline zaerst
  • Trade Count: (0)
« on: Tue, 05 April 2011, 17:50:02 »
SOLD
Set of 61 clear switch tops, stems, and springs. This is really meant for someone wanting a clear switch poker, hence 61 for the 61 keys of the poker.
No soldering/desoldering required. You'll just need to follow the guide of how to switch the tops and innards. It's pretty simple, just pop ans swap! Great DIY project to have a very unique board.
Best offer. PM pls.
« Last Edit: Fri, 08 April 2011, 14:57:36 by zaerst »
Offline zaerst
  • Trade Count: (0)
« Reply #1 on: Wed, 06 April 2011, 19:14:05 »
Bump... Nobody wants a clear poker??
Offline guilleguillaume
  • Trade Count: (0)
« Reply #2 on: Thu, 07 April 2011, 19:08:57 »
I could be interested but I don't actually know how much to pay for this kind of stuff. Want to give a try to Clears, who know if will like them!
Offline alaricljs
  • I be WOT'ing all day...
  • Trade Count: (0)
« Reply #3 on: Thu, 07 April 2011, 20:05:54 »
Quote from: guilleguillaume;326410
You can get a donor KB with ~130 clears for 35-55 depending on your timing/luck/chi.  Then you have to do the work to de-solder them.  Someone is/was unloading 109 for $40 shipped.
« Last Edit: Thu, 07 April 2011, 20:06:55 by alaricljs »
Filco w/ Imsto thick PBT
Offline kektr0city
  • Trade Count: (0)
« Reply #4 on: Thu, 07 April 2011, 20:41:13 »
Quote from: alaricljs;326426
see the op.  as long as their pcb mounted switches, you can utilize the method of switch modding that doesn't require any use of a solder iron.
Offline zaerst
  • Trade Count: (0)
« Reply #5 on: Thu, 07 April 2011, 21:51:10 »
They just feel like a heavier brown.
Offline iMav
  • geekhack creator/founder
  • Trade Count: (0)
« Reply #6 on: Thu, 07 April 2011, 22:45:47 »
Where did these come from?  Donor 'board?  And, if so, what keyboard?
