Author Topic: dvorak manual typewriter  (Read 3959 times)
Offline jolly_gnu
  • Trade Count: (0)
« on: Wed, 06 April 2011, 20:11:59 »
I'm ramping up my long stewing search to get a manual typewriter (that actually works) again and having been a lurker her for while I was wondering if anyone might know anyone or have a WORKING (I want to use it, not look at it), two-handed dvorak typewriter that they want to sell?
Make or model isn't really all that important.
After all the money I have spent because of geekhack, I'm hoping that someone can help me spend a little more :)
Offline xwhatsit
  • Trade Count: (0)
« Reply #1 on: Thu, 07 April 2011, 15:34:49 »
Can't you just remap the typebars with AutoHotKey?
Beam spring IBM 5251 (7361073/7362149) & IBM 3727 (5641316) | Model F IBM 122-key terminal & IBM PC-AT 84-key | Model M Unicomp 122-key terminal | Cherry MX Blue Leopold Tenkeyless
Offline jolly_gnu
  • Trade Count: (0)
« Reply #2 on: Thu, 07 April 2011, 16:25:32 »
Quote from: xwhatsit;326276
Actually, I had spent, about, two weeks overhauling an Olivetti Valentine to dvorak.  The problem is: the process is just too labor intense.  To cap it, as soon as I finished re-soldering all the type slugs and managing to get the alignment reasonable again, I broke two teeth out of the spreader while fixing a jamming issue (which makes the whole thing useless).  And after doing the work, I realized that I was never going to get as good an impression out of the type face as the factory--the slug always ended up being just a tad shallower in comparison.
So, I've just decided it can't be much more work to try and track one down.  I might be wrong.
Offline xwhatsit
  • Trade Count: (0)
« Reply #3 on: Thu, 07 April 2011, 20:38:57 »
Impressive. Didn't realise those were soldered.
