Author Topic: keyboard tray  (Read 10065 times)
Offline warealforce
keyboard tray
« on: Wed, 06 April 2011, 23:55:18 »
Does any of you use any keyboard tray?  Any recommendations on what to get?
Offline godofdeath
keyboard tray
« Reply #1 on: Thu, 07 April 2011, 00:03:37 »
you mean that thing that usually comes with the desk?
Offline warealforce
keyboard tray
« Reply #2 on: Thu, 07 April 2011, 00:10:04 »
:biggrin: I mean something that hopefully works better than that.  Like Humanscale.
Offline nocturn4l3030
keyboard tray
« Reply #3 on: Thu, 07 April 2011, 21:37:22 »
if you have a wooden desk, and you don't mind drilling holes, there's a TON of options on the internet if you just google it
if you're using a glass desk like me.. the only option i had (besides some really crappy keyboard trays) is to go to IKEA and get the Galant Table (it's on google / their website too).  It's adjustable in height and have different colors to match.  I pretty much just unscrewed the one that came with my desk and put it underneath the glass one.  It works perfectly for me
What happens when you discover GeekHack:
[strike]Black Ducky dk1087 Cherry (Brown)
Topre Realforce 103UB 55g
Cherry G80-8113HRBUS-2 (Clear)
White PLU ML-87 (Blue)
1990 IBM Model M 1391401
Cherry G80-3000LSCEU-0 (Blue)
[/strike]
Cherry G80-3600LYCEU-2 (Red)
Topre Realforce 86UB
Filco Tenkeyless (Brown)
[/SIZE]
Offline Lpb45
keyboard tray
« Reply #4 on: Thu, 07 April 2011, 21:38:37 »
I like just having mine flat on my desk, guess im weird
Topre - 86U   |   Filco - Tenkeyless Linear Red
Filco - Tenkeyless Blue       |   Filco - Fullsize Non NKRO Blue (Work)
Offline bionicroach
keyboard tray
« Reply #5 on: Thu, 07 April 2011, 21:52:46 »
If budget was no concern, I'd go with an adjustable desk like these...
AdjusTables
GeekDesk
...coupled with a monitor arm:
ErgoTron
That way you can get the desk at the right height for keyboarding / mousing and your monitor at a comfortable eye level.
But, since I'm poor, I built my own keyboard tray using heavy duty drawer slides like these (props to Ripster for the link):
Lee Valley Slides
Quality drawer slides are strong enough that you can use a hefty piece of plywood that's wide enough for all your gear and won't wobble like crappy plastic trays do.  I made my tray 32" wide and 18" deep, then covered the surface with a giant Ripper XXL mousepad cut to fit.  Works great.
I guess I tend to lean on the desk fairly hard, but I never have found an arm-mounted ergo tray that wasn't wobbly and fiddly compared to a good solid drawer-slide tray.  If you don't need adjustments like negative tilt, etc, then I really don't think the arm-mounted trays are a worthwhile investment.
Offline pitashen
keyboard tray
« Reply #6 on: Thu, 07 April 2011, 23:02:19 »
+ 1 to the Galant adjustable table.
For keyboard tray, anyone of those adjustable arm type should do decent job.
Offline vun
  • Just one more thing
keyboard tray
« Reply #7 on: Fri, 08 April 2011, 01:19:00 »
Quote from: Lpb45;326488
Me too, I can't stand keyboard trays.
Adjustable desks on the other hand... In my opinion way better than a keyboard tray. Sadly my desk isn't adjustable, that was a bit too expensive when I bought it. Luckily the manufacturer is located a 10 minute drive from here, so I can easily get them retrofitted if I want to.
Offline What is X?
keyboard tray
« Reply #8 on: Fri, 08 April 2011, 06:03:23 »
I have my keyboard on my desk and my mouse on the keyboard tray. I'm weird like that
Offline Megaweapon
keyboard tray
« Reply #9 on: Sun, 10 April 2011, 00:08:05 »
Mead-Hatcher 32030
I looked at pretty much every keyboard tray on the internet and thought this one was the widest available because the spec says 33 3/8".  It turns out that measurement is external dimension.  The tray itself is a mere 29 3/4" and unless you create an insert (like I did) you'll lose another 2" due to the little knobs.
New plan:  Go tenkeyless.
Ancer Research Groop DFK191ABA11 • IBM Model M13 Part 92G7461 (white) • Rosewill RK-9000
Matias Tactile Pro 3 • Apple Extended Keyboard II (ALPS)
• Rosewill RK-9000I
Offline rustybarnacle
keyboard tray
« Reply #10 on: Sun, 10 April 2011, 01:45:28 »
As previously stated, the IKEA galant is the answer for me.  The legs are height adjustable, so i lowered the desk to about 27", which gives me a good keyboard height, and then got a stand fo rmy monitor, so it's up high enough that i look at it straight on.  Do i use a keyboard tray? no.  But the desk accomplishes the same thing.  I can even stash my keyboard under the monitor stand to stow it if need be.
Offline Nautilus
keyboard tray
« Reply #11 on: Sun, 10 April 2011, 01:59:42 »
I'm the same way. My desk actually has a tray but I just use it for a place to put my wireless mouse and stereo remote. XD
Cherry Blues: Das Keyboard Professional S, Leopold Tenkeyless
Cherry Browns: Filco Tenkeyless (on the way)
Rubber Dome: QSENN DT-35 (aka SEM DT-35)
Mice: Razer Abyssus, Microsoft Wireless Desktop 1000
OS: Windows 7, Windows XP, Mac OS X Snow Leopard
Offline curiousjorge
Re: keyboard tray
« Reply #12 on: Wed, 29 May 2013, 02:15:55 »
Sorry to bump such an old post but has anyone found a way to mount a keyboard tray to a glass desk? I found this forum by googling 'keyboard tray for glass desk'
I am using the 3M sit stand keyboard tray. Can't fit my wood desk into my new apartment, its huuggge.
Re: keyboard tray
« Reply #13 on: Wed, 29 May 2013, 12:04:54 »
Found this btw, www.gds-products.com, going to buy it tomorrow unless I find a better method by then.
